I don’t know if this s possible but it would be nice to have the cluster spots the same color as in N1MM.
73, John N1JM
73, John N1JM
How did the developers of n1mm respond?
The colour of spots can be changed within settings, but this is just a single colour. If you mean worked/unworked, mult etc. this is a bit more complicated, but should be possible if you are using the UDP broadcast mode to receive spots. I will make a note to investigate this the next time I work on the spots function!
Ok Phil. Thanks. That’s what I meant. This happens using SSDR, PC or Mac, with my Flex and N1MM using UDP port 12060.
