I usually load up the latest daily build about once a week. The last one that works for me is from the 10th. When I try to open the one’s from the 11th, 12th or 13th I get a code execution error, Qt5Xml.dll not found. Try reinstalling the software. I tried reinstall the v1.5 software but it didn’t help. The error is correct, the Qt5Xml.dll is not in the wfview folder.
Hi Alan,
That file is available in the daily build and weekly build folder at the top.
https://www.wfview.org/public_builds/
Just place that file in the same folder as wfview and you should be good to go!
You were absolutely correct! All working fine now. Thanks!
