Version 1.2d at 2022-01-22 with the fullbuild-wfview.sh script
Raspi4 - OS Buster - screen size 1440x900
Wfview window size OK fits nicely into the screen
Version 1.2e at 2022-01-16 with the fullbuild-wfview.sh script
Wfview window size is much larger - doesn’t fit into screen
it seems it is at least double in size
When starting the older 1.2d version the wfview window is still fiitting into the screen.
To verify the problem I compiled:
Virtual machine Debian OS Bullseye - xfce desktop - screen size 1440x900
Wfview window size OK fits nicely into the screen.
What could be the problem at the Raspi that the 1.2e version gets this hughe size?
I have to mention that I connect to the Raspi with AnyDesk, but all icons and other programms have normal size, just 1.2e is out of limit. I don’t remeber if at the older compiling time I was connected via AnyDeask or directly working with external monitor / keyboard /mouse. Could this give a problem?
I haven’t seen this myself, but it is likely a consequence of adding support for High DPI displays. I had “assumed” that it would scale automatically for smaller displays, but obviously not!
I guess we will need to make it a configuration/command line option? In the meantime, commenting-out line 60 in main.cpp and then recompiling should return to the original behaviour?
I have an other raspi here with same OS (now I’m not at home, but in the garden) were I have all connected directly and will check if there is a difference in size to the AnyDesk connected one. If so, I will inform you.
compiling 1.2e on Raspi4 - OS Buster - directly connected to Full-HD Monitor via HDMI / Mouse/Keyboard via USB, with QT High DPI setting at line 60 in main.cpp.
Result:
Main window fills whole screen (1920x1050) and because of the menuebar (32x32) on top of the desktop, the buttons “About”, “Save Settings” etc. are not visible any more.
Had to shrink the main window vertical to get them, but it could not be done further, so the lower side of buttons is exactly out of lower boundary of screen. Horizontal Window ends inside the screen.
It means, that window doesn’t fit good on Full-HD screens, smaller screens are just cutting off the rest of main window. Seems this adaption function is only checking resolution in dpi’s but not taking into account the set screen size of desktop.
Hi Phil,
I did some reading concerning scaling. Let’s say I googled arround. Will recheck my settings because of headless configuration some parameters were fixed in the config.txt to let AnyDesk or other remote software to see a nice screen. Will let you know soon.
73 Michael
Hi Phil,
Problem is solved when using config.txt original version and hdmi display is connected.
Under appearence best result is medium screen for full hd display 1920x1080 px.
Problem still exists when trying to connect via AnyDesk and hdmi display is not connected => headless.
In this case AnyDesk reports no supported display or similar wording.
This was the reason I had to adapt the config.txt for the 1.2d version, what is now incombatible with the new QT parameter in 1.2e version.
Your wfview is ok on raspi4 compiling and working - my settings in config.txt for headless operation and remote control will make me loose some more of my white hairs. hihi
