Hi, I have an IC-705, WFVIEW and N1MM+ logger on a Microsoft Surface Pro 9
I want to send CW using N1MM+ logger via WLAN to the IC-705
Does WFVIEW support this?
73, TC
Hi.
Not directly, but you can connect N1MM+ to wfview via a virtual serial port. Sharing Control Overview | wfview
Hi Phil, thanks for your reply. I have N1MM+ connected to the IC-705 wirelessly through wvfiew using a virtual serial port. (N1MM+ is reflecting the frequency which I tune the radio to). But the CW, generated by N1MM+, does not key the IC-705. I have tried N1MM+ using direct USB connection (not using wfview) and it keys the IC-705 OK. So wondering whether there is a trick I’m missing to do CW wirelessly?
73, Tim
Hi Tim,
How are you keying the CW? N1MM supports multiple modes. If you are using DTR/RTS keying, then this cannot work, as this information isn’t available over WiFi/LAN connections.
The only method that can possibly work is “CW Keying Over CAT Commands” https://n1mmwp.hamdocs.com/setup/interfacing/#cw-keying-using-cat-commands
It is not as flexible as the other methods, as it simply tells the rig to send individual strings of characters, and isn’t officially supported by the N1MM+ developers. It also doesn’t allow you to use the N1MM+ CW keyboard to send (although you should be able to use the wfview CW window for this.
Ah, that’s useful to know; thanks Phil.
So it looks like I will have to revert to USB lead connection to use CW sending from N1MM+ keyboard… Fine except the USB link makes lots of noise on the upper HF bands! I’d better try even more ferrites!..
Thanks again for your help!
73, Tim
Hi Timbo,
I am now working on exactly the same… Initially I was thinking that I could send CW from whatever logger via RTS/CTS (CW/PTT) but it seems that I have to configure this within an ICOM7300 and then I lose the USB CI-V interface… It can either work as CW/PTT or CI-V… (Seems that IC7100 gives you two serial ports over USB so I have to set uo and test) but I was also thinking of using a remote computer or raspberry to simply have a WinKey connected to another usb/serial and either having n1mm+ running remotely and accessing the n1mm via UDP 12060(or whatever). I haven’t though tested if I can have a N1MM running as a “server”.
My idea would be - and that is feature request - to add a virtual comport to wfview, which would “emulate” the WinKey (limited) and would allow for simple - change Speed and send characters…nothin more. That way interfacing to logger wouldnt require any add. HW even for rigs like IC705/7610 etc. But I have no idea how hard that would be.
Jiri
Hi. I’ve connected our 7610 directly to wfview. Connected then N1MM via TCP to wfview and set the CW Macros like F4 {MYCALL},{CAT1HEX FEFE98e0174446315152FFFD}
Command 17 calls CW TX with the following ASC coded signs, ending by FF and FD to close the command. Surely it is not usable for contests but for a quick DXpedition or a new DXCC and a fast 5nn tu with
F2 Exch,{CAT1HEX FEFE98e017354E4E205455FFFD} and a EE like
F3 Tu,{CAT1HEX FEFE98e0174545FFFD}
it is ok. You can find a simple ASCII Table here. You have to change the CI-V Adress from 98 for IC_7610 to A4 for the IC-705.
73
Holger, DF1QR
