Brief summary of problem (put in title as well): Data mode not possible to switch on.
Radio Model: Kenwood TS890
Connectivity (USB/Ethernet/Wifi/Other): Ethernet
Operating System: Windows 11
wfview version (press “About”): 2.24
What I did: Switch on data mode in wfview.
Expected behavior: Data mode to switch on on TS890.
Observed behavior: Data mode is not switched on on TS890. However if i switch on data mode on TS890, it can be switched off in wfview.
This is sort of a known bug. The issue comes from how wfview started very Icom-centric. The data mode switch is handled slightly differently and not really curated correctly by our back end. We will probably get that fixed up in v3.
It’s actually more complicated than that, there are a number of commands that only work with certain modes (data/if-filter etc), in order to avoid lots of errors back from the radio, v3 will introduce a mode-specific query/periodic command to fix this.
