Hi Elliot,
Tried the installation today and here are a few lines before this error came up:
73 and Thanks
Raj
AK4EC /VU3VOC
…/wfview/pttyhandler.cpp:222:69: warning: ‘QTextStream& QTextStreamFunctions::hex(QTextStream&)’ is deprecated: Use Qt::hex [-Wdeprecated-declarations]
222 | qInfo(logSerial()) << “pty remote CI-V changed:” << hex << (quint8)civId;
In file included from /usr/include/i386-linux-gnu/qt5/QtCore/qdebug.h:49,
from /usr/include/i386-linux-gnu/qt5/QtCore/QDebug:1,
from …/wfview/freqmemory.h:4,
from …/wfview/rigidentities.h:9,
from …/wfview/pttyhandler.h:12,
from …/wfview/pttyhandler.cpp:1:
/usr/include/i386-linux-gnu/qt5/QtCore/qtextstream.h:277:74: note: declared here
277 | QT_DEPRECATED_VERSION_X(5, 15, “Use Qt::hex”) QTextStream &hex(QTextStream &s);
In file included from …/wfview/resampler/resample.c:100:
…/wfview/resampler/resample_sse.h: In function ‘inner_product_single’:
…/wfview/resampler/resample_sse.h:45:19: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
45 | for (i = 0; i < len; i += 8)
…/wfview/resampler/resample_sse.h: In function ‘interpolate_product_single’:
…/wfview/resampler/resample_sse.h:62:19: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
62 | for (i = 0; i < len; i += 2)
…/wfview/resampler/resample_sse.h: In function ‘inner_product_double’:
…/wfview/resampler/resample_sse.h:84:19: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
84 | for (i = 0; i < len; i += 8)
…/wfview/resampler/resample_sse.h: In function ‘interpolate_product_double’:
…/wfview/resampler/resample_sse.h:110:19: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
110 | for (i = 0; i < len; i += 2)
…/wfview/resampler/resample.c: In function ‘update_filter’:
…/wfview/resampler/resample.c:676:27: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
676 | for (j = 0; j < st->filt_len; j++)
…/wfview/resampler/resample.c: In function ‘wf_resampler_process_float’:
…/wfview/resampler/resample.c:953:31: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
953 | for (j = 0; j < ichunk; ++j)
…/wfview/resampler/resample.c:957:31: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
957 | for (j = 0; j < ichunk; ++j)
…/wfview/resampler/resample.c: In function ‘wf_resampler_process_int’:
…/wfview/resampler/resample.c:1009:31: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
1009 | for (j = 0; j < ichunk; ++j)
…/wfview/resampler/resample.c:1017:31: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
1017 | for (j = 0; j < ichunk; ++j)
…/wfview/resampler/resample.c:1028:23: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
1028 | for (j = 0; j < ochunk + omagic; ++j)
…/wfview/resampler/resample_sse.h:60:12: warning: SSE vector return without SSE enabled changes the ABI [-Wpsabi]
60 | __m128 sum = _mm_setzero_ps();
g++ -c -pipe -s -fvisibility=hidden -fvisibility-inlines-hidden -faligned-new -O2 -Wall -Wextra -D_REENTRANT -fPIC -DWFVIEW_VERSION=“1.2d” -DQT_DEPRECATED_WARNINGS -DQCUSTOMPLOT_COMPILE_LIBRARY -DUSE_SSE -DUSE_SSE2 -DOUTSIDE_SPEEX -DRANDOM_PREFIX=wf -DPREFIX="/usr/local" -DHOST="hostname
" -DUNAME="whoami
" -DGITSHORT=“f8351ad” -DQT_NO_DEBUG -DQT_MULTIMEDIA_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_SERIALPORT_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -I…/wfview -I. -I…/wfview/resampler -I/usr/include/i386-linux-gnu/qt5 -I/usr/include/i386-linux-gnu/qt5/QtMultimedia -I/usr/include/i386-linux-gnu/qt5/QtPrintSupport -I/usr/include/i386-linux-gnu/qt5/QtWidgets -I/usr/include/i386-linux-gnu/qt5/QtGui -I/usr/include/i386-linux-gnu/qt5/QtSerialPort -I/usr/include/i386-linux-gnu/qt5/QtNetwork -I/usr/include/i386-linux-gnu/qt5/QtCore -I. -I. -I/usr/lib/i386-linux-gnu/qt5/mkspecs/linux-g++ -o repeatersetup.o …/wfview/repeatersetup.cpp
In file included from …/wfview/resampler/resample_sse.h:37,
/usr/lib/gcc/i686-linux-gnu/10/include/xmmintrin.h:118:1: error: inlining failed in call to ‘always_inline’ ‘_mm_setzero_ps’: target specific option mismatch
118 | _mm_setzero_ps (void)
…/wfview/resampler/resample_sse.h:44:18: note: called from here
44 | __m128 sum = _mm_setzero_ps();
/usr/lib/gcc/i686-linux-gnu/10/include/xmmintrin.h:184:1: error: inlining failed in call to ‘always_inline’ ‘_mm_add_ps’: target specific option mismatch
184 | _mm_add_ps (__m128 __A, __m128 __B)
…/wfview/resampler/resample_sse.h:48:15: note: called from here
48 | sum = _mm_add_ps(sum, _mm_mul_ps(_mm_loadu_ps(a + i + 4), _mm_loadu_ps(b + i + 4)));
/usr/lib/gcc/i686-linux-gnu/10/include/xmmintrin.h:196:1: error: inlining failed in call to ‘always_inline’ ‘_mm_mul_ps’: target specific option mismatch
196 | _mm_mul_ps (__m128 __A, __m128 __B)
/usr/lib/gcc/i686-linux-gnu/10/include/xmmintrin.h:932:1: error: inlining failed in call to ‘always_inline’ ‘_mm_loadu_ps’: target specific option mismatch
932 | _mm_loadu_ps (float const *__P)
…/wfview/resampler/resample_sse.h:47:15: note: called from here
47 | sum = _mm_add_ps(sum, _mm_mul_ps(_mm_loadu_ps(a + i), _mm_loadu_ps(b + i)));
/usr/lib/gcc/i686-linux-gnu/10/include/xmmintrin.h:961:1: error: inlining failed in call to ‘always_inline’ ‘_mm_store_ss’: target specific option mismatch
961 | _mm_store_ss (float *__P, __m128 __A)
…/wfview/resampler/resample_sse.h:52:5: note: called from here
52 | _mm_store_ss(&ret, sum);
/usr/lib/gcc/i686-linux-gnu/10/include/xmmintrin.h:128:1: error: inlining failed in call to ‘always_inline’ ‘_mm_add_ss’: target specific option mismatch
128 | _mm_add_ss (__m128 __A, __m128 __B)
…/wfview/resampler/resample_sse.h:51:11: note: called from here
51 | sum = _mm_add_ss(sum, _mm_shuffle_ps(sum, sum, 0x55));
/usr/lib/gcc/i686-linux-gnu/10/include/xmmintrin.h:744:1: error: inlining failed in call to ‘always_inline’ ‘_mm_shuffle_ps’: target specific option mismatch
744 | _mm_shuffle_ps (__m128 __A, __m128 __B, int const __mask)
…/wfview/resampler/resample_sse.h:50:11: note: called from here
50 | sum = _mm_add_ps(sum, _mm_movehl_ps(sum, sum));
/usr/lib/gcc/i686-linux-gnu/10/include/xmmintrin.h:785:1: error: inlining failed in call to ‘always_inline’ ‘_mm_movehl_ps’: target specific option mismatch
785 | _mm_movehl_ps (__m128 __A, __m128 __B)
make: *** [Makefile:922: resample.o] Error 1
make: *** Waiting for unfinished jobs…
Error in make step.
wfview was not compiled.
Please consider posting the error(s) to https://forum.wfview.org/
