Hi there,
So I have a headless RPI setup as a portable wifi hotspot for portable use in the field, and I have connected the IC-705 to the RPI and I have connected my phone to the RPI.
I can ping the IC-705 from the RPI directly and from the phone, but I don’t understand why I am getting such delayed pings----between 250 and 900ms from the phone and slightly better direct from the RPI. That dosent make sense to me with the phone and the 705 just inches from the PI and nothing else connected here in testing at home but it is an overall improvement from when the IC-705 batter saver was on which apparently was the cause of even worse results.
First question, is that normal with an IC-705? What is an expected response time to a ping to a 705?
I have wfview installed on the RPI, I have confirmed that I have the correct username and password in wfview, but I can’t connect to the RPI. The log would seem to indicate a problem with lost packets, but why?
Also, is it possible that this setup is not compatible with wfview? The ic-705 being in station mode, with the RPI as a hotspot AND the RPI being where wfview is operating from?
73 and thanks!
Tom
I apparently can’t upload a log file yet as a new user but here is a text excerpt:
2023-01-26 13:50:17.116 INF udp: Closing UDP stream : “10.0.0.143” : 50001
2023-01-26 14:04:29.993 INF udp: Starting udpHandler user: “N2YTF” rx latency: 312 tx latency: 314 rx sample rate: 16000 rx codec: 4 tx sample rate: 16000 tx codec: 4
2023-01-26 14:04:29.994 INF udp: UDP Stream bound to local port: 49852 remote port: 50001
2023-01-26 14:04:29.997 INF system: Received CommReady!!
2023-01-26 14:04:29.997 INF default: Setting rig state for wfmain
2023-01-26 14:04:29.998 INF default: Setting rig state
2023-01-26 14:04:31.124 INF udp: udpHandler : Received I am here from: QHostAddress(“::ffff:10.0.0.143”)
2023-01-26 14:04:31.160 INF udp: udpHandler : Received I am here from: QHostAddress(“::ffff:10.0.0.143”)
2023-01-26 14:04:31.161 INF udp: udpHandler : Received I am here
2023-01-26 14:04:31.434 INF udp: udpHandler : Received I am ready
2023-01-26 14:04:31.435 INF udp: udpHandler : Sending login packet
2023-01-26 14:04:31.613 INF udp: udpHandler : Received I am ready
2023-01-26 14:04:31.613 INF udp: udpHandler : Sending login packet
2023-01-26 14:04:31.947 INF udp: Got connection type: “FTTH”
2023-01-26 14:04:31.948 INF udp: udpHandler : Token response did not match, sent: 61411 got 64498
2023-01-26 14:04:31.948 INF udp: udpHandler : Detected connection speed FTTH
2023-01-26 14:04:31.978 INF udp: udpHandler : sending request for missing packet : “0x3”
2023-01-26 14:04:32.078 INF udp: udpHandler : sending request for missing packet : “0x3”
2023-01-26 14:04:32.178 INF udp: udpHandler : sending request for missing packet : “0x3”
2023-01-26 14:04:32.278 INF udp: udpHandler : sending request for missing packet : “0x3”
2023-01-26 14:04:32.378 INF udp: udpHandler : No response for missing packet “0x3” deleting
2023-01-26 14:04:33.078 INF udp: udpHandler : sending request for multiple missing packets : “06:00:06:00:07:00:07:00:08:00:08:00:09:00:09:00:0a:00:0a:00:0b:00:0b:00:0c:00:0c:00:0d:00:0d:00:0e:00:0e:00:0f:00:0f:00:10:00:10:00”
2023-01-26 14:04:33.178 INF udp: udpHandler : sending request for multiple missing packets : “06:00:06:00:07:00:07:00:08:00:08:00:09:00:09:00:0a:00:0a:00:0b:00:0b:00:0c:00:0c:00:0d:00:0d:00:0e:00:0e:00:0f:00:0f:00:10:00:10:00”
2023-01-26 14:04:33.278 INF udp: udpHandler : sending request for multiple missing packets : “06:00:06:00:07:00:07:00:08:00:08:00:09:00:09:00:0a:00:0a:00:0b:00:0b:00:0c:00:0c:00:0d:00:0d:00:0e:00:0e:00:0f:00:0f:00:10:00:10:00:12:00:12:00”
2023-01-26 14:04:33.379 INF udp: udpHandler : sending request for multiple missing packets : “06:00:06:00:07:00:07:00:08:00:08:00:09:00:09:00:0a:00:0a:00:0b:00:0b:00:0c:00:0c:00:0d:00:0d:00:0e:00:0e:00:0f:00:0f:00:10:00:10:00:12:00:12:00”
2023-01-26 14:04:33.478 INF udp: udpHandler : No response for missing packet “0x6” deleting
2023-01-26 14:04:33.478 INF udp: udpHandler : No response for missing packet “0x7” deleting
2023-01-26 14:04:33.479 INF udp: udpHandler : No response for missing packet “0x8” deleting
2023-01-26 14:04:33.479 INF udp: udpHandler : No response for missing packet “0x9” deleting
2023-01-26 14:04:33.479 INF udp: udpHandler : No response for missing packet “0xa” deleting
2023-01-26 14:04:33.479 INF udp: udpHandler : No response for missing packet “0xb” deleting
2023-01-26 14:04:33.479 INF udp: udpHandler : No response for missing packet “0xc” deleting
2023-01-26 14:04:33.485 INF udp: udpHandler : No response for missing packet “0xd” deleting
2023-01-26 14:04:33.485 INF udp: udpHandler : No response for missing packet “0xe” deleting
2023-01-26 14:04:33.485 INF udp: udpHandler : No response for missing packet “0xf” deleting
2023-01-26 14:04:33.486 INF udp: udpHandler : No response for missing packet “0x10” deleting
2023-01-26 14:04:33.486 INF udp: udpHandler : sending request for missing packet : “0x12”
2023-01-26 14:04:33.578 INF udp: udpHandler : sending request for missing packet : “0x12”
2023-01-26 14:04:33.678 INF udp: udpHandler : No response for missing packet “0x12” deleting
2023-01-26 14:04:34.279 INF udp: udpHandler : sending request for multiple missing packets : “15:00:15:00:16:00:16:00:17:00:17:00:18:00:18:00:19:00:19:00:1a:00:1a:00:1b:00:1b:00”
2023-01-26 14:04:34.378 INF udp: udpHandler : sending request for multiple missing packets : “15:00:15:00:16:00:16:00:17:00:17:00:18:00:18:00:19:00:19:00:1a:00:1a:00:1b:00:1b:00”
2023-01-26 14:04:34.478 INF udp: udpHandler : sending request for multiple missing packets : “15:00:15:00:16:00:16:00:17:00:17:00:18:00:18:00:19:00:19:00:1a:00:1a:00:1b:00:1b:00”
2023-01-26 14:04:34.578 INF udp: udpHandler : sending request for multiple missing packets : “15:00:15:00:16:00:16:00:17:00:17:00:18:00:18:00:19:00:19:00:1a:00:1a:00:1b:00:1b:00”
2023-01-26 14:04:34.679 INF udp: udpHandler : No response for missing packet “0x16” deleting
2023-01-26 14:04:34.680 INF udp: udpHandler : No response for missing packet “0x17” deleting
2023-01-26 14:04:34.680 INF udp: udpHandler : No response for missing packet “0x18” deleting
2023-01-26 14:04:34.681 INF udp: udpHandler : No response for missing packet “0x19” deleting
2023-01-26 14:04:34.681 INF udp: udpHandler : No response for missing packet “0x1a” deleting
2023-01-26 14:04:34.681 INF udp: udpHandler : No response for missing packet “0x1b” deleting
2023-01-26 14:04:35.579 INF udp: udpHandler : sending request for multiple missing packets : “20:00:20:00:21:00:21:00:22:00:22:00:23:00:23:00:24:00:24:00:25:00:25:00:26:00:26:00:27:00:27:00”
2023-01-26 14:04:35.679 INF udp: udpHandler : sending request for multiple missing packets : “20:00:20:00:21:00:21:00:22:00:22:00:23:00:23:00:24:00:24:00:25:00:25:00:26:00:26:00:27:00:27:00”
2023-01-26 14:04:35.779 INF udp: udpHandler : sending request for multiple missing packets : “20:00:20:00:21:00:21:00:22:00:22:00:23:00:23:00:24:00:24:00:25:00:25:00:26:00:26:00:27:00:27:00”
2023-01-26 14:04:35.879 INF udp: udpHandler : sending request for multiple missing packets : “20:00:20:00:21:00:21:00:22:00:22:00:23:00:23:00:24:00:24:00:25:00:25:00:26:00:26:00:27:00:27:00”
2023-01-26 14:04:35.978 INF udp: udpHandler : No response for missing packet “0x20” deleting
2023-01-26 14:04:35.978 INF udp: udpHandler : No response for missing packet “0x21” deleting
2023-01-26 14:04:35.978 INF udp: udpHandler : No response for missing packet “0x22” deleting
2023-01-26 14:04:35.979 INF udp: udpHandler : No response for missing packet “0x23” deleting
2023-01-26 14:04:35.979 INF udp: udpHandler : No response for missing packet “0x24” deleting
2023-01-26 14:04:35.979 INF udp: udpHandler : No response for missing packet “0x25” deleting
2023-01-26 14:04:35.979 INF udp: udpHandler : No response for missing packet “0x26” deleting
2023-01-26 14:04:35.979 INF udp: udpHandler : No response for missing packet “0x27” deleting
Tom, N2YTF
