I’m trying to operate Split Mode in CW to work E51D. He’s on 14002 kHz and listening “1 up”. I set Split to TX on 14032 kHz. However, when I transmit my VFO displays 31.000 MHz and the spectrum displays on a 31 on my TX freq. The display is set to Center and 2.5 kHz display bandwidth.
What can I do about this?
I tried to capture screenshots to back up my claim but Win-11 doesn’t let you use PrtSc anymore. Now you have to stand on your head and press Win-Alt-S then select the part of the display you want. Impossible to do when you’re sending your callsign at 28 wpm.
Also just noticed that when I TX in split, wfview drops my TX power from 100W down to 50-60W during TX. It goes back up to 100W after TXing.
I also tried setting an offset (1.3 kHz) as opposed to entering a discrete frequency (14.0031 MHz). The VFO still displays 31.0000 MHz on TX and 31 is still shown on the spectrum scale.
you refer to 100W → 50…60W. This is what the meter shows? If so, combine this with 31 MHz and then I could conclude that you are actually transmitting out of band?
For 31 MHz vs .0031 MHz – I could think of wrongly defining the offset.
Sorry, this is what the Pwr slider control does. I didn’t have time to watch the Power meter. Specifying a 1.31 kHz offset or entering a discreet frequency 1.31 kHz higher than the RX freq shouldn’t put me out-of-band. My RX freq at the time was 14001 kHz and he was listening up 1 kHz.
