Wfview vi.1 - IC-7610 using built-in server - Latest ver of win 10 on windows tablet.
I have a problem with distorted audio when using Wfview remote through my local VPN. On Wfview I see the latency goes way up to where the numbers change to red. Other then this the program seem to work work fine. Also, I had no complaints about my TX audio being distorted.
When I switch to RS-BA1 or Wins4icomsuite (using Icom Utility) , I don’t have this problem. They work fine and the RX audio is good.Changing back to Wfview I get the distorted RX audio.
What is Wfview doing different?
I like using Wfview on my tablet because it uses a lot less resources and is less cluttered making it more touch friendly.
This is almost certainly due to packet fragmentation as the VPN overhead will be causing each individual packet to be larger than the maximum allowed size for a UDP packet.
The quickest and easiest way to fix this is to reduce the sample rate. 24000 will 1/2 the packet size and bandwidth required (I think that RSBA1 uses 16000 by default?) 24000 is more than sufficient for SSB or NFM use though.
I use RS-BA1 on a daily basis w/ my remote station. WFview is gaining favor on me, but it will need several more cycles to be my daily driver.
Along the way if you need a hand with RS-BA1, I may have an answer or know how to do what you need to keep it running.
I don’t really like the RS-BA1 program but do use the utility portion to connect to IC-7610 server. I then use Win4icomsuite and connect it to the Icom Utility program. it works well for me that way.
I too look forward to future development of Wfview. It uses less resources and has a simple interface. However there are a few things it needs to add to be fully usable for me.
