Hi I have a IC-7610 (running transverter…but should not influence this issue)
Main VFO set for FT8 by WSJT-X, SUB VFO for listening SSB
After changed from WFVIEW 1.5x to 1.6X it is a “mudy” behavior
If I chose SUB VFO and change frequency this freq go to WSJT-X but data to WSJT-X is still from main VFO receiver.
I know you are working on dual watch feature.
But is there a work around to prevent this behavior ?
Br
Knud
phil
(Phil Taylor M0VSE)
22 April 2023 14:41
2
There is no work around at the moment, wfview has NO knowledge of the Sub VFO.
When I shift to SUB VFO (on the IC-7610) then WFVIEW show the SUB freq
When you say WFVIEW has no knowlegde of the SUB VFO ?
Br
Knud
phil
(Phil Taylor M0VSE)
22 April 2023 15:44
4
That’s because it DOESN"T KNOW that it is the SUB VFO, just the CURRENT VFO!
Hello Phil, I have the problem with the 1.63 version, the client as a Windows version runs very well! but if I want to set up the server on the Raspberry 4 with 1.63, it now breaks off with an error message during the installation. Version 1.62 still worked perfectly. any thoughts on this??? Vy 73 Jan-Peter -DL3KVT
phil
(Phil Taylor M0VSE)
26 April 2023 11:09
6
No thoughts at all with that information to be honest. The actual error message would be useful!
phil
(Phil Taylor M0VSE)
28 April 2023 19:20
8
apt-get install libudev-dev
