I noticed that dxcluster functions are added to the 1.57 but how to use them? I managed to add a server. That was a bit tricky. I had to also give the :portnumber in the server name box to get access to the rest of the boxes. So I can now see the server in the registry in windows. But how do I connect to the cluster? There is no connect button and it does not auto connect.
Tried to look in the documentation but could not find anything.
Otherwise it looks great. Now only missing split operation. And cw of course.
After successfully connecting to a cluster server, what do/can we do with that data? I see it flowing in the settings window, and I’ve seen references to it on the waterfall, but it appears the documentation has caught up to the features yet. 73, Tim W8TGB
wfview will show you, on the upper portion of the frequency spectrum (above the waterfall), locations where stations have been heard. You’ll see the callsigns show up.
What you can do with the data is find interesting stations to listen to and/or communicate with.
thanks @eliggett. Do I need to enable the spots on the waterfall is my real question. Because I don’t see any. (and I do know what the cluster is for )
I’m having the same issue with spots not showing on the waterfall. wfview 2.03 is connecting to rbn.telegraphy.de port 7000 and showing spots, but it isn’t showing the spots on the waterfall. Below are a few spots shown in the settings screen. Are there other settings that need to be set to get them to show on the waterfall?
DX de VE6JY-#: 14057.0 TM3STU CW 11 dB 18 WPM CQ 1757Z
DX de VE6JY-#: 14051.0 K5PE CW 19 dB 21 WPM CQ 1757Z
DX de VE6WZ-#: 28044.0 K3ES CW 9 dB 20 WPM CQ 1757Z
DX de AC0C-1-#: 14051.0 K5PE CW 27 dB 21 WPM CQ 1757Z
DX de W3OA-#: 14051.0 K5PE CW 14 dB 21 WPM CQ 1757Z
Can you verify that your scope is ranged to show those frequencies, plus and minus some KHz, and also, that the floor and ceiling sliders are set to show the full spectrum?
I’ve got N1MM accessing the cluster as well and change the frequency by clicking on them there most of the time to tune in a station. It tunes to the frequency and I hear and see the station centered on the graphs (not the callsign), so at least it should be in range. The Ceiling is set to the Max and Floor is set to the Min. I’m probably missing something obvious.
Robert
DX de ON6ZQ-#: 10116.3 OM3CAZ CW 12dB Q:9 Z:15,20 1355Z
DX de F8UKP-#: 14020.9 UR5UEY CW 10dB Q:9* Z:15,18,20 1355Z
DX de S53F-#: 10127.5 DL7DAX CW 14dB Q:9* Z:14 1355Z
DX de GI4DOH-#: 7031.5 DK1VD CW 7dB Q:9 Z:15 1355Z
DX de TI7W-#: 28016.0 II4FPUS CW 17dB Q:2 Z:5 1355Z
DX de NG7M-#: 14043.6 K1SM CW 10dB Q:9*+ Z:4,5,7,32 1355Z
I have just connected to the cluster you mentioned originally, and the format looks slightly different, with slightly more padding, which may be the issue?
DX de OH6BG-#: 14058.5 R1OA CW 25 dB 21 WPM CQ 1352Z
DX de BD7DT-#: 18069.8 V73WW CW 29 dB 39 WPM CQ 1352Z
DX de KM3T-3-#: 14031.0 NE5A CW 26 dB 27 WPM CQ 1352Z
DX de HA1VHF-#: 28017.8 VE3RIA CW 4 dB 30 WPM CQ 1352Z
DX de IK3STG-#: 28017.9 VE3RIA CW 4 dB 30 WPM CQ 1352Z
