DXLOG - QRG CAT not properly working
Hello
testing Wfview from Dx-Log for remote operation.
My config is: IC7300 + Pi + Wfview 1.64 linked via VPN to home pc.
I can properly use cat form Vfview at home.
From Dx-log I connect via TCP to Wfview (127.0.0.1:port) and I get the correct QRG. Changing QRG from Wfview (or radio too) are reported on Dx-Log.
But… when I try to change QRG from Dx-log I need to repeat the change several times to see changes in Wfview. I can clearly see it when I use up/down fine tuning (alt+up alt +down), QRG follow my command one time every… 4 or less.
I tried also with N1MM getting same result or connecting via TCP at IP-of-VPN-station:port talking directly to Wfview on PI.
Any clue?
73, Silvio IZ5DIY
