enable headset microphone
I just installed WF View, Windows 10 and it works great with my IC-7300. One of the things I have yet to figure out is how to use a mic on my laptop as the mic for the radio. What do I need to do to make it work if in fact, it will work?
Please see the FAQ.
wfview does not use the USB audio from the radio unless you are running a wfview server for remote access.
You can use software within windows to “redirect” the mic audio from a pc microphone into the radio. Someone here can probably recommend some software.
please keep in mind that you have to configure the voice input on your 7300 accordingly (MIC or USB). This can be done via WFView Server or the IC7300 Menu.
Thomas, DL3EL
Thanks for the information
