Hello
Ive been trying to test out the creator-widgets branch but having problems.
im using linux MInt. The default branch builds perfectly and produces a solid application. *(thanks!) but trying the creator-widgets build i get:
../wfview/bandbuttons.cpp: In member function ‘void bandbuttons::receiveCache(cacheItem)’:
../wfview/bandbuttons.cpp:40:16:warning: this statement may fall through [-Wimplicit-fallthrough=]
40 | sub=true;
| ~~~^~~~~../wfview/bandbuttons.cpp:41:9:note: here
41 | case funcMainFreq:
^Cmake: *** Deleting file 'bandbuttons.o'
make: *** [Makefile:1469: bandbuttons.o] Interrupt
This is repeated several times. It builds an executable that I can go into settings but when it connects to radio, touching any controls causes segment fault.
I suspect Im jumping ahead and missing something vital!
As creator-widgets involves some major changes to the way the software operates, it requires installation as each rig is now defined using individual .rig files which must be copied to a readable system directory.
If you decide to revert to master, running make install again should replace the wfview binary and it has no knowledge of the rig files so should still work.
