I have tried several times with a brand new script downloaded from github.
My log was sent here: https://termbin.com/e5ju3
I’ve had a couple of friends recommend kappanhang as it seems to just work for them. Is that a good option?
Hi Mark.
What operating system/platform? This looks like an issue that I have seen with older Raspberry Pi computers due to memory exhaustion but it’s difficult to say.
Kappanhang provides a very basic interface compared to wfview.
Kappanhang basically tx rx, so. Only controls on the cli.
Do a make only w/o the j param
It’s a RaspberryPi 3B+. I expect memory is the issue. I installed Kappanhang and it works very well, although it is indeed very basic. I’m getting a RaspberryPi 4 next and doubt I will have any problems installing Wfview.
Thanks!
Per @roeland If you edit the build script and change:
make -j2
to:
make
Then it may compile without any issues. Make the edit and then run the script again, it will probably work.
I’m trying with a Raspberry pi 4 and I get “no such file or directory” for libudev.h. Log file at termbin.com/lbvh.
Dennis Engdahl
NR6J
Hi Dennis.
Two things:
In answer to your question, please enter the following command to install libudev:
sudo apt-get install libudev-dev
You are so right! Sorry - I even remember seeing that command earlier!
Dennis
while it’s fixed, I thing it’s important for people to have them introduced to google.
the first (!) 61.300 results I have here with the question:
directly will give the answer(s).
Above is not personally directed but just a remark that it does help to get yourself better if you search things yourself first. A spoon-fed answer will not hold as good as having to google it first.
