Hi can you please help me, im getting this error during the installation process at 91%
Cannot start "C:\program Files(x86) \wfview\VC_redist.x86.exe/passive/norestart:Process failed to start::The system cannot find the file specified.
You can safely ignore the message. You may already have that file (Microsoft redistributable) installed. If wfview fails to run with a missing .dll error, you can manually install the redistributable.
Either run vc_redist.x86.exe that is in the wfview installation directory or download and install it from Microsoft.
Hi Phil
Thank you for your reply, I will try to run the file as suggested and if not download it and run.
Thanks again Phil I’ll try later.
73 Paul G4PDC
