Is there a way to export the settings?
I have installed WFview on several computers and would like to copy the settings and apply them to the other PCs (changed colors etc.)
73´ René
73´ René
Under windows this is not currently possible. You didn’t really mention your OS so I assume it is windows?
It’s not possible directly, but if you pass a --settings command line argument (as described in Command-Line Arguments | wfview ) it will create a .conf file (rather than using the Windows registry) which you can then then copy to a new machine.
By default, wfview uses the Windows registry, so you can use the standard Registry import/export tools. The wfview key is HKLM\Software\wfview (care should always be taken when manually modifying the registry)
thanks for the answers, yes it is for Windows.
I will try it with command, thanks already.
73´ René
