-----LAN------.> Pop OS! 22.04 LTS (an ubuntu derivative)
ok, that said. the machine at the radio (wfview server) was built by ‘full-build’ script. it reports v1.65. and the remote machine (client) is running the flatpak version (1.64)
I cannot seem to control the frequency using the client wfview. I change the VFO using the dial in wfview and then it flips back after 3 seconds to original frequency
what am i doing wrong? everything else seems to work including audio
The most likely cause of this is that the client is unable to identify the radio model. It uses CI-V transceive for this, so you MUST leave CI-V address set to auto on both the client and server and enable CI-V transceive on the radio.
You can usually tell if the radio has been identified, by the right-hand side of the wfview taskbar area, it will show the radio model. If it says NONE then the radio hasn’t been detected.
73
Phil M0VSE
