Garage to house setup
HI, I am running windows 11 in my house about 80’ from my garage where I want to get a IC-7300 to transmit from house on either Wfview or HDSDR when I get my license.
What is best way to connect them ? Can I do it wirelessly or will a usb extender with
cat 7 exterior cable be better. Also I do have a computer in garage that is wireless to the house already. Also will I need to use a panadapter or any other hardware to make it work ? Thanks 4 any advice
Use a Raspberry Pi or normal desktop computer to your ham shack and run wfview as a server on that computer. Then run the Cat 7 (or Cat 5 or Cat 6) from your garage to the house and put it on the network.
Then, you can use your IC-7300 by installing wfview on a laptop or another PC in your house. And optionally, you can setup port forwarding and use it outside of your house as well.
https://wfview.org/wfview-user-manual/remote-operation-server/
Elliott, So do I run the cat 6 cable from the server computer to my router in the house
or can I run it direct to the client computer I will be using ? also thanks for the user manual that helps alot Dave
Hi Dave,
I recommend running the cable from the server computer to the router. This way you can take advantage of things the router offers such as DHCP.
Thanks hope to get it done in spring
