So now, for some reason, since I setup the wfview server and client I’m getting hamlib error from jtdx.
Hamlib error: Communications bus error while getting VFO frequency.
Communication timed out while getting current VFO frequency.
Hamlib error: Command rejected by the rig while getting frequency.
Hamlib error: Rig failure
This error pops up at least once and hour or more.
This one is fairly frequent also.
This error is more intermittent than 1), maybe once or twice a day.
I’ve only seen this error once.
My setup is a 7300, wfview, jrdx (or wxjt-x), GT, and log4om. Jtdx is connects via a VSPE pair of vitual ports. Log40m is connected via Hamlib port 4532.
The only way I’ve gotten these errors to stop is to turn off CI-V Transceive in the 7300. Problem with that is I lose the waterfall on the wfview client remote PC.
I can still see the waterfall in wfview if I connect to the radio (server) PC using Remote Desktop Connection and setup wfview to connect to the radio manually, just can’t see it on the remote (client) PC.
I don’t really need the waterfall if I’m working ft8 or ft4 since jtdx, or wsjt-x, has a waterfall, but it could be useful working ssb voice, although I guess I could just use sdrconsole.
Anyone have any other ideas?
