IC-703 does not start on version 2.03
Wfview working without any problem with version 1.64, by upgrading to version 2.03, the following messages came out in the log and did not start.
2025-01-29 13:46:06.408 INF system: wfview version: 2.03 (Git:ed9a02a on Jan 3 2025 at 21:03:22 by phil.taylor@PHIL-WIN11)
2025-01-29 13:46:06.408 INF system: Operating System: Windows 10 Version 2009 (i386)
2025-01-29 13:46:06.408 INF system: Looking for External Dependencies:
2025-01-29 13:46:06.408 INF system: QT Runtime Version: 5.15.2
2025-01-29 13:46:06.408 INF system: OPUS Version: libopus 1.5.1-19-g95dbea83
2025-01-29 13:46:06.408 INF system: HIDAPI Version: 0.14.0
2025-01-29 13:46:06.408 INF system: EIGEN Version: 3.4.90
2025-01-29 13:46:06.408 INF system: QCUSTOMPLOT Version: 2.1.1
2025-01-29 13:46:06.408 INF system: RTAUDIO Version: 6.0.1
2025-01-29 13:46:06.408 INF system: PORTAUDIO Version: PortAudio V19.7.0-devel, revision unknown
2025-01-29 13:46:06.408 INF default: Starting caching queue handler thread (ThreadId: 0x2808 )
2025-01-29 13:46:06.493 INF default: “Found New User Rig IC-703 with CI-V address of 0x44 version 2.02”
2025-01-29 13:46:06.499 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2025-01-29 13:46:06.539 INF gui: Got Audio Output from Settings: “スピーカー (Synaptics HD Audio)”
2025-01-29 13:46:06.539 INF gui: Got Audio Input from Settings: “ステレオ ミキサー (Synaptics HD Audio)”
2025-01-29 13:46:06.542 INF default: tciServer() listening on 50001
2025-01-29 13:46:06.553 INF default: Setting color Preset 0 name “Dark”
2025-01-29 13:46:06.557 INF audio: Audio device(s) found (*=default)
2025-01-29 13:46:06.627 INF audio: * ( 2 “wasapi” ) Input Device : “ライン入力 (Synaptics HD Audio)”
2025-01-29 13:46:06.627 INF audio: ( 3 “wasapi” ) Input Device : “ステレオ ミキサー (Synaptics HD Audio)”
2025-01-29 13:46:06.658 INF audio: * ( 1 “wasapi” ) Output Device : “スピーカー (Synaptics HD Audio)”
2025-01-29 13:46:06.658 INF default: Looking for inputs
2025-01-29 13:46:06.658 INF default: Looking for outputs
2025-01-29 13:46:06.658 INF audio: "Client Audio input device ステレオ ミキサー (Synaptics HD Audio) found! "
2025-01-29 13:46:06.658 INF audio: "Client Audio output device スピーカー (Synaptics HD Audio) found! "
2025-01-29 13:46:06.743 INF default: Changing queue interval to 250 ms
2025-01-29 13:46:06.743 INF rig: creating instance of rigCommander()
2025-01-29 13:46:06.743 INF rig: creating instance of icomCommander()
2025-01-29 13:46:06.743 INF cluster: starting dxClusterClient()
2025-01-29 13:46:06.753 INF serial: Opened port: “COM5”
2025-01-29 13:46:06.838 INF default: Changing queue interval to 100 ms
2025-01-29 13:46:06.838 INF system: Delay command interval timing: 100 ms
2025-01-29 13:46:07.048 INF rig: “Have new rig ID: 0x68”
2025-01-29 13:46:07.048 INF rig: “No rig definition found for CI-V address: 0x68, using defaults (some functions may not be available)”
2025-01-29 13:46:07.053 INF rig: “Loading Rig: IC-703 from C:/Program Files (x86)/wfview/rigs/IC-703.rig”
2025-01-29 13:46:07.057 INF serial: Setting half duplex comms: Enabled
2025-01-29 13:46:07.057 INF rig: Using incomingCIVAddr: (int): 104 hex: “0x68”
2025-01-29 13:46:07.057 INF default: Receiving rigcaps into repeater setup.
2025-01-29 13:46:07.057 INF default: repeaterSetup got rigcaps for: “IC-703”
2025-01-29 13:46:07.057 INF system: Running configureVFOs()
2025-01-29 13:46:07.108 INF default: Changing queue interval to 100 ms
2025-01-29 13:46:07.108 INF system: Delay command interval timing: 100 ms
2025-01-29 13:46:07.108 INF system: Start periodic commands (and delete unsupported)
2025-01-29 13:46:07.593 INF rig: Occasional error response (FA) from rig can safely be ignored
2025-01-29 13:46:07.593 WRN rig: Error (FA) received from rig, last command sent:
2025-01-29 13:46:07.593 WRN rig: “---- Begin hex dump -----:”
2025-01-29 13:46:07.593 WRN rig: "DATA: fe fe 68 e1 10 fd "
2025-01-29 13:46:07.593 WRN rig: "INDEX: 00 01 02 03 04 05 "
2025-01-29 13:46:07.593 WRN rig: “---- End hex dump -----”
2025-01-29 13:46:08.148 WRN rig: Error (FA) received from rig, last command sent:
2025-01-29 13:46:08.148 WRN rig: “---- Begin hex dump -----:”
2025-01-29 13:46:08.148 WRN rig: "DATA: fe fe 68 e1 10 fd "
2025-01-29 13:46:08.148 WRN rig: "INDEX: 00 01 02 03 04 05 "
2025-01-29 13:46:08.148 WRN rig: “---- End hex dump -----”
2025-01-29 13:46:10.528 WRN rig: Error (FA) received from rig, last command sent:
2025-01-29 13:46:10.528 WRN rig: “---- Begin hex dump -----:”
2025-01-29 13:46:10.528 WRN rig: "DATA: fe fe 68 e1 10 fd "
2025-01-29 13:46:10.528 WRN rig: "INDEX: 00 01 02 03 04 05 "
2025-01-29 13:46:10.528 WRN rig: “---- End hex dump -----”
Please let me know any way to get rid of this.
Thank you
Kohji Ebihara
JA1STO
Hi Kohji,
Unfortunately we have not added the IC-703 to version 2 yet.
Here is a list of what’s current in Version 2: Supported Radios and Features | wfview
With that said, if you are comfortable, you can open the IC-706 rig file and modify it for the IC-703 by changing the CI-V address. I think the commands are otherwise the same.
Here is some information on the RigFile. You can use wfview to graphically edit the file and then save it. If successful, please send it to us and we will incorporate it into our official repository.
Dear Mr Liggett
With your advice, by using IC-706.rig file, wfview started the program.
After adding commands to the file, finally restore the control to the IC-703.
There is, however, strange errors in the log file. It is appreciated to have
some advice to solve those errors.
2025-02-02 14:16:13.118 INF default: Changing queue interval to 100 ms
2025-02-02 14:16:13.118 INF system: Delay command interval timing: 100 ms
2025-02-02 14:16:13.118 INF system: Start periodic commands (and delete unsupported)
2025-02-02 14:16:13.273 INF system: receiveMode “Received new mode for Main: 0 (LSB) filter:1 data:255”
2025-02-02 14:16:13.471 INF rig: Occasional error response (FA) from rig can safely be ignored
2025-02-02 14:16:13.471 WRN rig: Error (FA) received from rig, last command sent:
2025-02-02 14:16:13.471 WRN rig: “---- Begin hex dump -----:”
2025-02-02 14:16:13.471 WRN rig: "DATA: fe fe 68 e1 10 fd "
2025-02-02 14:16:13.472 WRN rig: "INDEX: 00 01 02 03 04 05 "
2025-02-02 14:16:13.472 WRN rig: “---- End hex dump -----”
2025-02-02 14:16:13.773 WRN rig: Error (FA) received from rig, last command sent:
2025-02-02 14:16:13.773 WRN rig: “---- Begin hex dump -----:”
2025-02-02 14:16:13.774 WRN rig: "DATA: fe fe 68 e1 14 07 fd "
2025-02-02 14:16:13.774 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-02 14:16:13.774 WRN rig: “---- End hex dump -----”
Thank you
Kohji Ebihara
JA1STO
Hi Kohji,
Nice work, you’re almost there.
The warnings are about commands which are in the rig file and need to be removed.
If you open the file you created in Rig Creator, you can look at the list of Commands.
The first command (0x10) is probably labeled “Tuning Step”. Right-click on Tuning Step and select “Delete”. It could have another label though. Just look for any command with the string column which matches “\x10”.
The second command (0x14 0x07) may be labeled “PBT Inner”, but again it could have some other label. Regardless, find the item where the string column entry is “\x14\x17” and right-click and delete that as well.
Save the file and then restart wfview.
If you see other “FA” messages often, check back in the rig file for unsupported commands. It’s easy to accidentally have a few.
Once you are satisfied with the file, pleas send it to us :slight_smile:
Mr. Liggett
Finally IC-703 came to connect and be controllable.
Your cooperation is very much appreciated.
The followings are logs on windows11 and ubuntu 24.04.
Windows11
2025-02-04 12:40:24.307 INF system: wfview version: 2.03 (Git:ed9a02a on Jan 3 2025 at 21:05:03 by phil.taylor@PHIL-WIN11)
2025-02-04 12:40:24.307 INF system: Operating System: Windows 11 Version 24H2 (x86_64)
2025-02-04 12:40:24.307 INF system: Looking for External Dependencies:
2025-02-04 12:40:24.307 INF system: QT Runtime Version: 6.8.1
2025-02-04 12:40:24.307 INF system: OPUS Version: libopus 1.5.1-19-g95dbea83
2025-02-04 12:40:24.308 INF system: HIDAPI Version: 0.14.0
2025-02-04 12:40:24.308 INF system: EIGEN Version: 3.4.90
2025-02-04 12:40:24.308 INF system: QCUSTOMPLOT Version: 2.1.1
2025-02-04 12:40:24.309 INF system: RTAUDIO Version: 6.0.1
2025-02-04 12:40:24.309 INF system: PORTAUDIO Version: PortAudio V19.7.0-devel, revision unknown
2025-02-04 12:40:24.310 INF default: Starting caching queue handler thread (ThreadId: 0x1d10 )
2025-02-04 12:40:24.365 INF default: “Found User Rig IC-703 with CI-V address of 0x68 and newer or same version than system one (2.03>=2.03)”
2025-02-04 12:40:24.367 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2025-02-04 12:40:24.401 INF gui: Got Audio Output from Settings: “スピーカー (Synaptics HD Audio)”
2025-02-04 12:40:24.401 INF gui: Got Audio Input from Settings: “ステレオ ミキサー (Synaptics HD Audio)”
2025-02-04 12:40:24.405 INF default: tciServer() listening on 50001
2025-02-04 12:40:24.413 INF default: Setting color Preset 0 name “Dark”
2025-02-04 12:40:24.508 INF audio: Audio device(s) found (*=default)
2025-02-04 12:40:24.530 INF audio: * ( 0 ) Input Device : “ライン入力 (Synaptics HD Audio)”
2025-02-04 12:40:24.530 INF audio: ( 1 ) Input Device : “ステレオ ミキサー (Synaptics HD Audio)”
2025-02-04 12:40:24.533 INF audio: * ( 0 ) Output Device : “スピーカー (Synaptics HD Audio)”
2025-02-04 12:40:24.533 INF default: Looking for inputs
2025-02-04 12:40:24.535 INF default: Looking for outputs
2025-02-04 12:40:24.536 INF audio: "Client Audio input device ステレオ ミキサー (Synaptics HD Audio) found! "
2025-02-04 12:40:24.536 INF audio: "Client Audio output device スピーカー (Synaptics HD Audio) found! "
2025-02-04 12:40:24.604 INF default: Changing queue interval to 250 ms
2025-02-04 12:40:24.606 INF rig: creating instance of rigCommander()
2025-02-04 12:40:24.606 INF rig: creating instance of icomCommander()
2025-02-04 12:40:24.606 INF cluster: starting dxClusterClient()
2025-02-04 12:40:24.617 INF serial: Opened port: “COM5”
2025-02-04 12:40:24.676 INF default: Changing queue interval to 100 ms
2025-02-04 12:40:24.676 INF system: Delay command interval timing: 100 ms
2025-02-04 12:40:24.907 INF rig: “Have new rig ID: 0x68”
2025-02-04 12:40:24.907 INF rig: “Loading Rig: IC-703 from C:/Users/Kohji Ebihara/AppData/Roaming/wfview/wfview/rigs/IC-703.rig”
2025-02-04 12:40:24.909 INF serial: Setting half duplex comms: Enabled
2025-02-04 12:40:24.909 WRN rig: **** Function “AGC Status” Not Found, rig file may be out of date?
2025-02-04 12:40:24.909 WRN rig: Cannot find periodic command “Tuning Step” in rigcaps, ignoring
2025-02-04 12:40:24.909 INF rig: Using incomingCIVAddr: (int): 104 hex: “0x68”
2025-02-04 12:40:24.909 INF default: Receiving rigcaps into repeater setup.
2025-02-04 12:40:24.909 INF default: repeaterSetup got rigcaps for: “IC-703”
2025-02-04 12:40:24.909 INF system: Running configureVFOs()
2025-02-04 12:40:24.959 INF default: Changing queue interval to 100 ms
2025-02-04 12:40:24.959 INF system: Delay command interval timing: 100 ms
2025-02-04 12:40:24.959 INF system: Start periodic commands (and delete unsupported)
Ubuntu 24.04
2025-02-04 12:50:01.588 INF system: wfview version: 2.03 (Git:34838fa on Feb 1 2025 at 13:08:36 by kebihara@kebihara-HP-ProDesk-400-G5-SFF)
2025-02-04 12:50:01.588 INF system: Operating System: Ubuntu 24.04.1 LTS (x86_64)
2025-02-04 12:50:01.588 INF system: Looking for External Dependencies:
2025-02-04 12:50:01.588 INF system: QT Runtime Version: 5.15.13
2025-02-04 12:50:01.588 INF system: OPUS Version: libopus 1.4
2025-02-04 12:50:01.588 INF system: HIDAPI Version: 0.14.0
2025-02-04 12:50:01.588 INF system: EIGEN Version: 3.4.0
2025-02-04 12:50:01.588 INF system: QCUSTOMPLOT Version: 2.1.0
2025-02-04 12:50:01.588 INF system: RTAUDIO Version: 5.2.0
2025-02-04 12:50:01.588 INF system: PORTAUDIO Version: PortAudio V19.6.0-devel, revision 396fe4b6699ae929d3a685b3ef8a7e97396139a4
2025-02-04 12:50:01.593 INF default: Starting caching queue handler thread (ThreadId: 0x786c6e0006c0 )
2025-02-04 12:50:01.699 INF default: “Found New User Rig IC-703 with CI-V address of 0x68 version 2.03”
2025-02-04 12:50:01.701 INF system: Loading settings from “/home/kebihara/.config/wfview/wfview.conf”
2025-02-04 12:50:01.753 INF gui: Got Audio Output from Settings: “default”
2025-02-04 12:50:01.754 INF gui: Got Audio Input from Settings: “default”
2025-02-04 12:50:01.754 INF default: tciServer() listening on 50001
2025-02-04 12:50:02.188 INF default: Looking for inputs
2025-02-04 12:50:02.189 INF default: Looking for outputs
2025-02-04 12:50:02.261 INF default: Setting color Preset 0 name “Dark”
2025-02-04 12:50:02.294 INF audio: "Client Audio input device default found! "
2025-02-04 12:50:02.294 INF audio: "Client Audio output device default found! "
2025-02-04 12:50:02.297 INF default: Changing queue interval to 250 ms
2025-02-04 12:50:02.298 INF rig: creating instance of rigCommander()
2025-02-04 12:50:02.298 INF rig: creating instance of icomCommander()
2025-02-04 12:50:02.298 INF cluster: starting dxClusterClient()
2025-02-04 12:50:02.300 INF serial: Opened port: “/dev/ttyACM0”
2025-02-04 12:50:02.378 INF default: Changing queue interval to 100 ms
2025-02-04 12:50:02.379 INF system: Delay command interval timing: 100 ms
2025-02-04 12:50:02.597 INF rig: “Have new rig ID: 0x68”
2025-02-04 12:50:02.600 INF rig: “Loading Rig: IC-703 from /home/kebihara/.local/share/wfview/wfview/rigs/IC-703.rig”
2025-02-04 12:50:02.600 INF serial: Setting half duplex comms: Enabled
2025-02-04 12:50:02.601 WRN rig: Cannot find periodic command “Tuning Step” in rigcaps, ignoring
2025-02-04 12:50:02.603 INF rig: Using incomingCIVAddr: (int): 104 hex: “0x68”
2025-02-04 12:50:02.603 INF default: Receiving rigcaps into repeater setup.
2025-02-04 12:50:02.604 INF default: repeaterSetup got rigcaps for: “IC-703”
2025-02-04 12:50:02.604 INF system: Running configureVFOs()
2025-02-04 12:50:02.675 INF default: Changing queue interval to 100 ms
2025-02-04 12:50:02.675 INF system: Delay command interval timing: 100 ms
2025-02-04 12:50:02.675 INF system: Start periodic commands (and delete unsupported)
2025-02-04 12:50:02.899 INF system: receiveMode “Received new mode for Main: 0 (LSB) filter:1 data:255”
2025-02-04 12:50:03.306 INF default: Band Buttons found current band: “40m”
Thank you
Kohji Ebihara
JA1STO
IC-703.rig (16.1 KB)
