Hello,
Looking for some help. I seem to be connected to the radio but I have no waterfall nor are any of the settings from the radio showing and crazy high latency (90-144ms) even though I am in a good WiFi location with strong signal. Below is my log, any help would be appreciated!
Mike
2023-02-23 20:09:32.699 INF system: “wfview version: 1.61 (Git:b373685 on Feb 7 2023 at 20:18:52 by build@wfview.org). Operating System: Windows 11 Version 2009 (x86_64). Build Qt Version 6.3.2. Current Qt Version: 6.3.2”
2023-02-23 20:09:32.719 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2023-02-23 20:09:32.760 INF rigctld: started on port 4533
2023-02-23 20:09:32.760 INF gui: Got Audio Output from Settings: “CABLE Input (VB-Audio Virtual Cable)”
2023-02-23 20:09:32.760 INF gui: Got Audio Input from Settings: “CABLE Output (VB-Audio Virtual Cable)”
2023-02-23 20:09:32.777 INF audio: Audio device(s) found (*=default)
2023-02-23 20:09:32.795 INF audio: * ( 0 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2023-02-23 20:09:32.795 INF audio: ( 1 ) Input Device : “Microphone (CORSAIR ST100 Headset Output)”
2023-02-23 20:09:32.795 INF audio: ( 2 ) Input Device : “Headset Microphone (CORSAIR HS80 RGB Wireless Gaming Headset)”
2023-02-23 20:09:32.796 INF audio: ( 3 ) Input Device : “Microphone (C922 Pro Stream Webcam)”
2023-02-23 20:09:32.796 INF audio: ( 4 ) Input Device : “Headset Microphone (CORSAIR HS80 RGB USB Gaming Headset)”
2023-02-23 20:09:32.801 INF audio: * ( 0 ) Output Device : “Digital Audio (S/PDIF) (Realtek(R) Audio)”
2023-02-23 20:09:32.801 INF audio: ( 1 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2023-02-23 20:09:32.801 INF audio: ( 2 ) Output Device : “LC49G95T (NVIDIA High Definition Audio)”
2023-02-23 20:09:32.801 INF audio: ( 3 ) Output Device : “Headset Earphone (CORSAIR HS80 RGB Wireless Gaming Headset)”
2023-02-23 20:09:32.801 INF audio: ( 4 ) Output Device : “Headset Earphone (CORSAIR HS80 RGB USB Gaming Headset)”
2023-02-23 20:09:32.801 INF audio: ( 5 ) Output Device : “Headphones (CORSAIR ST100 Headset Output)”
2023-02-23 20:09:32.801 INF default: Looking for inputs
2023-02-23 20:09:32.801 INF audio: "Client Audio input device CABLE Output (VB-Audio Virtual Cable) found! "
2023-02-23 20:09:32.801 INF default: Looking for outputs
2023-02-23 20:09:32.802 INF audio: "Client Audio output device CABLE Input (VB-Audio Virtual Cable) found! "
2023-02-23 20:09:32.803 INF audio: “Server Audio input device Headset Microphone (CORSAIR HS80 RGB USB Gaming Headset) found! "
2023-02-23 20:09:32.803 INF audio: “Server Audio output device Headset Earphone (CORSAIR HS80 RGB USB Gaming Headset) found! "
2023-02-23 20:09:32.920 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2023-02-23 20:09:32.923 INF rig: creating instance of rigCommander()
2023-02-23 20:09:32.924 INF cluster: starting dxClusterClient()
2023-02-23 20:09:32.924 INF udp: Starting udpHandler user: “mike” rx latency: 150 tx latency: 150 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2023-02-23 20:09:32.927 INF serial: Could not open pseudo terminal port, please restart.
2023-02-23 20:09:32.927 INF udp: UDP Stream bound to local port: 49782 remote port: 50001
2023-02-23 20:09:32.959 INF system: Received CommReady!!
2023-02-23 20:09:32.959 INF default: Setting rig state for wfmain
2023-02-23 20:09:33.587 INF udp: udpHandler : Received I am here from: QHostAddress(”::ffff:192.168.4.112”)
2023-02-23 20:09:33.692 INF udp: udpHandler : Received I am ready
2023-02-23 20:09:33.692 INF udp: udpHandler : Sending login packet
2023-02-23 20:09:33.713 INF udp: Got connection type: “FTTH”
2023-02-23 20:09:33.713 INF udp: udpHandler : Received matching token response to our request
2023-02-23 20:09:33.713 INF udp: udpHandler : Detected connection speed FTTH
2023-02-23 20:09:33.720 INF udp: udpHandler “Received radio capabilities, Name: IC-705, Audio: ICOM_VAUDIO, CIV: a4, MAC: 00:90:c7:0e:5f:ed CAPF: 5001”
2023-02-23 20:09:33.720 INF udp: Got Connection status for: IC-705 Busy: 0 Computer IP “0.0.0.0”
2023-02-23 20:09:33.720 INF udp: Got Radio 0
2023-02-23 20:09:33.720 INF udp: Find available local ports
2023-02-23 20:09:33.721 INF default: Received serial port baud rate from remote server: 19200
2023-02-23 20:09:33.721 INF system: Delay command interval timing: 75 ms
2023-02-23 20:09:33.729 INF udp: Starting udpCivData
2023-02-23 20:09:33.729 INF udp: UDP Stream bound to local port: 49783 remote port: 50002
2023-02-23 20:09:33.729 INF udp: Starting udpAudio
2023-02-23 20:09:33.729 INF udp: UDP Stream bound to local port: 49784 remote port: 50003
2023-02-23 20:09:33.729 INF udp: udpHandler Got serial and audio request success, device name: “IC-705”
2023-02-23 20:09:33.729 INF udp: Got Connection status for: IC-705 Busy: 1 Computer TheFarm-wfview IP “192.168.4.94”
2023-02-23 20:09:33.730 INF audio: Output audio handler starting: “CABLE Input (VB-Audio Virtual Cable)”
2023-02-23 20:09:33.730 INF audio: Input audio handler starting: “CABLE Output (VB-Audio Virtual Cable)”
2023-02-23 20:09:33.730 INF audio: Input thread id 0xd80
2023-02-23 20:09:33.730 INF audio: Input start() running
2023-02-23 20:09:33.731 INF audio: Output thread id 0x40e4
2023-02-23 20:09:33.731 INF audio: Output start() running
2023-02-23 20:09:33.731 INF audioconverter: Starting audioConverter() Input: 1 Channels of 0 48000 Int16 Output: 2 Channels of 0 48000 Int16
2023-02-23 20:09:33.731 INF audioconverter: Starting audioConverter() Input: 2 Channels of 0 48000 Int16 Output: 1 Channels of 0 48000 Int16
2023-02-23 20:09:33.737 INF udp: udpCivData : Received I am here
2023-02-23 20:09:33.737 INF udp: udpAudio : Received I am here
2023-02-23 20:09:50.723 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2023-02-23 20:09:53.724 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2023-02-23 20:09:56.364 INF udp: udpAudio : sending request for multiple missing packets : “bc:08:bc:08:bd:08:bd:08:be:08:be:08”
2023-02-23 20:09:56.474 INF udp: udpAudio : sending request for multiple missing packets : “bc:08:bc:08:bd:08:bd:08:be:08:be:08”
2023-02-23 20:09:56.582 INF udp: udpAudio : sending request for multiple missing packets : “bc:08:bc:08:bd:08:bd:08:be:08:be:08”
2023-02-23 20:09:56.692 INF udp: udpAudio : sending request for multiple missing packets : “bc:08:bc:08:bd:08:bd:08:be:08:be:08”
2023-02-23 20:09:56.802 INF udp: udpAudio : No response for missing packet “0x8bc” deleting
2023-02-23 20:09:56.802 INF udp: udpAudio : No response for missing packet “0x8bd” deleting
2023-02-23 20:09:56.802 INF udp: udpAudio : No response for missing packet “0x8be” deleting
2023-02-23 20:10:01.223 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2023-02-23 20:10:02.271 INF udp: udpAudio : sending request for missing packet : “0xb17”
2023-02-23 20:10:02.380 INF udp: udpAudio : sending request for missing packet : “0xb17”
2023-02-23 20:10:02.488 INF udp: udpAudio : sending request for missing packet : “0xb17”
2023-02-23 20:10:02.598 INF udp: udpAudio : sending request for missing packet : “0xb17”
2023-02-23 20:10:02.707 INF udp: udpAudio : No response for missing packet “0xb17” deleting
2023-02-23 20:10:05.224 INF udp: udpAudio : sending request for multiple missing packets : “34:0c:34:0c:35:0c:35:0c:36:0c:36:0c”
2023-02-23 20:10:05.332 INF udp: udpAudio : sending request for multiple missing packets : “34:0c:34:0c:35:0c:35:0c:36:0c:36:0c”
2023-02-23 20:10:05.442 INF udp: udpAudio : sending request for multiple missing packets : “34:0c:34:0c:35:0c:35:0c:36:0c:36:0c”
2023-02-23 20:10:05.551 INF udp: udpAudio : sending request for multiple missing packets : “34:0c:34:0c:35:0c:35:0c:36:0c:36:0c”
2023-02-23 20:10:05.629 INF udp: udpHandler : sending request for missing packet : “0x13e”
2023-02-23 20:10:05.662 INF udp: udpAudio : No response for missing packet “0xc34” deleting
2023-02-23 20:10:05.662 INF udp: udpAudio : No response for missing packet “0xc35” deleting
2023-02-23 20:10:05.662 INF udp: udpAudio : No response for missing packet “0xc36” deleting
2023-02-23 20:10:05.741 INF udp: udpHandler : sending request for missing packet : “0x13e”
2023-02-23 20:10:05.850 INF udp: udpHandler : sending request for missing packet : “0x13e”
2023-02-23 20:10:05.960 INF udp: udpHandler : sending request for missing packet : “0x13e”
2023-02-23 20:10:06.068 INF udp: udpHandler : No response for missing packet “0x13e” deleting
2023-02-23 20:10:12.770 INF udp: udpAudio : sending request for missing packet : “0xf25”
2023-02-23 20:10:12.880 INF udp: udpAudio : sending request for missing packet : “0xf25”
2023-02-23 20:10:12.992 INF udp: udpAudio : sending request for missing packet : “0xf25”
2023-02-23 20:10:13.098 INF udp: udpAudio : sending request for missing packet : “0xf25”
2023-02-23 20:10:13.209 INF udp: udpAudio : No response for missing packet “0xf25” deleting
2023-02-23 20:10:19.725 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2023-02-23 20:10:19.989 INF udp: udpAudio : sending request for missing packet : “0x1200”
2023-02-23 20:10:19.989 INF udp: udpCivData : sending request for missing packet : “0x635”
2023-02-23 20:10:20.100 INF udp: udpAudio : sending request for missing packet : “0x1200”
2023-02-23 20:10:20.100 INF udp: udpCivData : sending request for missing packet : “0x635”
2023-02-23 20:10:20.209 INF udp: udpAudio : sending request for missing packet : “0x1200”
2023-02-23 20:10:20.209 INF udp: udpCivData : sending request for missing packet : “0x635”
2023-02-23 20:10:20.316 INF udp: udpAudio : sending request for missing packet : “0x1200”
2023-02-23 20:10:20.316 INF udp: udpCivData : sending request for missing packet : “0x635”
2023-02-23 20:10:20.426 INF udp: udpAudio : No response for missing packet “0x1200” deleting
2023-02-23 20:10:20.426 INF udp: udpCivData : No response for missing packet “0x635” deleting
2023-02-23 20:10:27.223 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
