Hi, Im using Bluetooth virtual com port to control from JTDX VB cable to redirect audio from Wfview to JTDX, im seeing/hearing a burst of white noise at the start of every TX.
regards
Grahame
regards
Grahame
Hi Graeme
Are you using a separate VB Cable pair for TX and RX? If not, you will likely find that the RX audio output is being fed into the TX input for a fraction of a second (until the RX audio is muted). Multiple VB Cables requires a purchased copy of the VB Cable software as the free one only provides a single input/output pair.
I was using a single VB Cable, i have purchased the A+B VB Cable now and it works perfectly thanks for your swift and expert reply
73 M6GDT Grahame
