After a longer way to get my wifi connection between ic 705 and my Macbook stable, I still have some trouble with the CAT connection. A few time per hour WSJT-X tells me that the CAT connection is gone. I can then click “ok” in wsjt-x and everything is fine again. I am using the virtual serial port “…/rig-pty1” (configured in wfview and wjt-x). I am contiuous running a ping towards the 705, and when the issue occurs, the pings are ok. So I assume that it’s probably not a wifi problem. Any ideas how to solve that?
BTW, I found that on the 705, the TCP port 60000 is open. What is it used for?
Thanks for your answers. Phil, I am using 1.2c already.
I changed the wsjt-x settings for the serial connection from “default” to 8N1, not sure whether this will improve the situation.
@Roeland: only the tcp port 60000 is open, the other tcp ports are closed.
