IC 705 - Open repeater incl. 1750 toneburst
Hi, managed to install the latest version by compiling the source.
an I am be able to connect to my Ic 705 remotely.
However to be able to activate a repeater i need to issue a 1750Hz Toneburst. Which buttons I do have to push in wfview to be able to activate a repeater ?
Regards, hitam
I am not aware of a remote (C-IV) command to initiate the 1750 Hz toneburst on the IC-705.
As far as I know, the only way to use toneburst is to assign “T-CALL” to the button on the remote MIC (as described in the manual) but wfview can’t use this.
Well Phil, thank you very much for your quick reply.
regards, hitam
