I set it up for use with an Icom 7100. When tuning with scroll wheel, it initially starts tuning but then selects wild frequencies from 163.444 Mhz to 214Khz. I tried using it locally through the USB connection, as well as remotely from another computer on the LAN using the server. Also the band selection doesn’t seem to work.
Should I see (on the client end when operating remotely) IC-7100 in the lower right corner. It does not appear.
FWIW, the audio stream seems to work.
Charlie KB8CR
