Just what is the DS setting controlling and are there any setting that can be changed after turning it on?
Paul, WG0G
Paul, WG0G
It is actually controlling the filter type, the DS button was erroneously added to the IC7300 rig file, it will be removed in the next version, it should control the DigiSel setting, which the IC7300 doesn’t have.
Phil,
Thank you for your answer!!
I thought I was loosing it. Couldn’t find any info on the ic-7300 and what it was. (If I ever had it!)
73
Paul, WG0G
it now controls filtershape sharp/soft
