Hi I try to explain the issue as a object:
Radio Model: IC-7300
Connectivity (USB/Ethernet/Wifi/Other): USB (via KVM switch, also tested direct)
Operating System: macOS 16.5 (Mac mini M4)
wfview version (press “About”): 2.11
Checked the wfview manual (Y/N): N
Tried to google it (Y/N/NA): N
What I did
I connected the IC-7300 via USB to my Mac mini M4 running macOS 16.5. The USB cable passes through a KVM switch, since I’m testing multiple platforms (macOS, Windows, Raspberry Pi OS, Ubuntu on Raspberry Pi). wfview 2.11 detects the radio, and the connection is reported as successful in the status line.
To rule out the KVM switch as the cause, I also tested using a direct USB connection between the radio and the Mac, but the issue persists.
Expected behavior
The GUI should display the waterfall and enable the radio control interface (frequency, mode, etc.).
Observed behavior
The GUI remains mostly gray. No waterfall is shown, and the controls are missing or inactive, despite the software indicating that the radio is successfully connected.
Thanks.
Carmelo IT9GHW.
