I’ve used WFVIEW to control my IC-705 and it works very well. According to the user manual, the new IC-905 is one of the core supported radios however when I try to connect to mine, it only partially works. I can see the radio in the “Radio status window” and I get audio but no display of CAT info and in the lower right corner where my IC-705 shows up it says “NONE”. Using all the default ports (same as the IC-705 just a different IP address.
Due to a number of differences with the IC905, it isn’t supported by the current released version of wfview. We are currently working on a revamped version that will include support for the IC-905, but it is not ready for use yet.
If you need to connect to a IC-905 remotely, I can give you access or I can set up a Teamviewer account on a separate PC on the same segment as my 905, whatever I can do to assist I will be more than happy to help.
HA HA !!! I know that feeling!! We are building a new house and all my “extra” time is spent working on it !! Least we never forget, this is just a hobby…
