IC7300 memories issue
Hello I use Wfview with both IC9700 and IC7300 radios.
I can’t use the memory function with my IC7300. It works well with the IC9700.
I use the latest version
I can see the memories window but the Disable editing button is grayed out and canot be activated…
I’m logged as Admin user
I searched every where and cannot find why it now works with IC7300 while it works fine with IC9700
Could you please help
73
Pascal
What version of wfview are you running on your server?
Hi I can see 2.04 on the RPi
Ah ok.
We are preparing to do another release soon so I will check this.
OK so I have found the issue. There was a check for whether the user is an admin user in the server code which was backwards.
This is now fixed in the master branch, so you can either rebuild your server using this, or change the user to a “non-admin” user. Either should work.
