I have successfully setup WFview with my IC7300. I’m running windows 10 on an HP desktop PC. The desktop PC is connected to the IC7300 with a 30 ft USB printer cable located in a room upstairs from my hamshack. I can control the rig with no problem but I cannot get the audio output or mic input working from the PC. My goal is operate SSB using my Plantronics (hardwired) head
set which are connected to the USB port on the desktop. I have verified that the Plantronics headset boom microphone and the earphones are working properly. I pasted the WFVIEW log (from today) below. Any help would be appreciated.
Greg N2GWN
2024-02-14 12:26:00.004 INF system: “wfview version: 1.64 (Git:b4c079f on Jul 16 2023 at 14:29:30 by build@wfview.org). Operating System: Windows 10 Version 22H2 (x86_64). Build Qt Version 6.5.1. Current Qt Version: 6.5.1”
2024-02-14 12:26:00.048 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2024-02-14 12:26:00.118 INF rigctld: started on port 4533
2024-02-14 12:26:00.120 INF gui: Got Audio Output from Settings: “Speakers / Headphones (Realtek Audio)”
2024-02-14 12:26:00.120 INF gui: Got Audio Input from Settings: “Headset Microphone (Plantronics Blackwire 3220 Series)”
2024-02-14 12:26:00.210 INF cw: “Sidetone Output: Headset Earphone (Plantronics Blackwire 3220 Series) (volume: 0 rate: 44100 type: 2”
2024-02-14 12:26:00.211 INF audio: Audio device(s) found (=default)
2024-02-14 12:26:00.216 INF audio: * ( 0 ) Input Device : “Headset Microphone (Plantronics Blackwire 3220 Series)”
2024-02-14 12:26:00.218 INF audio: ( 1 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2024-02-14 12:26:00.218 INF audio: ( 2 ) Input Device : “Microphone (2- USB Audio CODEC )”
2024-02-14 12:26:00.227 INF audio: * ( 0 ) Output Device : “Headset Earphone (Plantronics Blackwire 3220 Series)”
2024-02-14 12:26:00.228 INF audio: ( 1 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2024-02-14 12:26:00.228 INF audio: ( 2 ) Output Device : “S271HL (Intel(R) Display Audio)”
2024-02-14 12:26:00.228 INF audio: ( 3 ) Output Device : “Speakers (2- USB Audio CODEC )”
2024-02-14 12:26:00.229 INF audio: ( 4 ) Output Device : “Speakers / Headphones (Realtek Audio)”
2024-02-14 12:26:00.229 INF default: Looking for inputs
2024-02-14 12:26:00.231 INF audio: "Client Audio input device Headset Microphone (Plantronics Blackwire 3220 Series) found! "
2024-02-14 12:26:00.231 INF default: Looking for outputs
2024-02-14 12:26:00.232 INF audio: "Client Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 12:26:00.235 INF audio: "Server Audio input device Microphone (2- USB Audio CODEC ) found! "
2024-02-14 12:26:00.236 INF audio: "Server Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 12:26:00.494 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2024-02-14 12:26:00.500 INF rig: creating instance of rigCommander()
2024-02-14 12:26:00.501 INF system: Serial Port found: “COM3” Manufacturer: “Silicon Labs” Product ID “Silicon Labs CP210x USB to UART Bridge” S/N “IC-7300_02056911”
2024-02-14 12:26:00.502 INF cluster: starting dxClusterClient()
2024-02-14 12:26:00.508 INF serial: Opened port: “COM3”
2024-02-14 12:26:00.596 INF system: Received CommReady!!
2024-02-14 12:26:00.596 INF system: Delay command interval timing: 75 ms
2024-02-14 12:26:00.596 INF default: Setting rig state for wfmain
2024-02-14 12:26:06.850 INF serial: Opened port: “COM3”
2024-02-14 12:26:12.836 INF serial: Opened port: “COM3”
2024-02-14 12:26:17.031 INF serial: Opened port: “COM3”
2024-02-14 12:26:19.998 INF rig: Using incomingCIVAddr: (int): 148 hex: “0x94”
2024-02-14 12:26:19.998 INF serial: Received rigCapabilities for “IC-7300”
2024-02-14 12:26:19.998 INF rig: Have rig ID: decimal: 148
2024-02-14 12:26:19.999 INF rigctld: Got rigcaps for: “IC-7300”
2024-02-14 12:26:20.014 INF system: Delay command interval timing: 25 ms
2024-02-14 12:26:20.193 INF serial: Opened port: “COM3”
2024-02-14 12:58:00.745 INF audio: Audio device(s) found (=default)
2024-02-14 12:58:00.893 INF audio: * ( 0 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2024-02-14 12:58:00.893 INF audio: ( 1 ) Input Device : “Microphone (2- USB Audio CODEC )”
2024-02-14 12:58:00.901 INF audio: * ( 0 ) Output Device : “Speakers / Headphones (Realtek Audio)”
2024-02-14 12:58:00.902 INF audio: ( 1 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2024-02-14 12:58:00.903 INF audio: ( 2 ) Output Device : “S271HL (Intel(R) Display Audio)”
2024-02-14 12:58:00.903 INF audio: ( 3 ) Output Device : “Speakers (2- USB Audio CODEC )”
2024-02-14 12:58:00.903 INF default: Looking for inputs
2024-02-14 12:58:00.903 INF audio: “Client Audio input device Headset Microphone (Plantronics Blackwire 3220 Series) Not found: Selecting default device CABLE Output (VB-Audio Virtual Cable)”
2024-02-14 12:58:00.903 INF default: Looking for outputs
2024-02-14 12:58:00.907 INF audio: "Client Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 12:58:00.911 INF audio: "Server Audio input device Microphone (2- USB Audio CODEC ) found! "
2024-02-14 12:58:00.911 INF audio: "Server Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 12:58:00.920 INF audio: Audio device(s) found (=default)
2024-02-14 12:58:00.920 INF audio: * ( 0 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2024-02-14 12:58:00.920 INF audio: ( 1 ) Input Device : “Microphone (2- USB Audio CODEC )”
2024-02-14 12:58:00.928 INF audio: * ( 0 ) Output Device : “Speakers / Headphones (Realtek Audio)”
2024-02-14 12:58:00.928 INF audio: ( 1 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2024-02-14 12:58:00.928 INF audio: ( 2 ) Output Device : “S271HL (Intel(R) Display Audio)”
2024-02-14 12:58:00.928 INF audio: ( 3 ) Output Device : “Speakers (2- USB Audio CODEC )”
2024-02-14 12:58:00.928 INF default: Looking for inputs
2024-02-14 12:58:00.932 INF audio: "Client Audio input device CABLE Output (VB-Audio Virtual Cable) found! "
2024-02-14 12:58:00.932 INF default: Looking for outputs
2024-02-14 12:58:00.932 INF audio: "Client Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 12:58:00.936 INF audio: "Server Audio input device Microphone (2- USB Audio CODEC ) found! "
2024-02-14 12:58:00.936 INF audio: "Server Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 12:58:00.940 INF audio: Audio device(s) found (=default)
2024-02-14 12:58:00.940 INF audio: * ( 0 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2024-02-14 12:58:00.944 INF audio: ( 1 ) Input Device : “Microphone (2- USB Audio CODEC )”
2024-02-14 12:58:00.948 INF audio: * ( 0 ) Output Device : “Speakers / Headphones (Realtek Audio)”
2024-02-14 12:58:00.948 INF audio: ( 1 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2024-02-14 12:58:00.948 INF audio: ( 2 ) Output Device : “S271HL (Intel(R) Display Audio)”
2024-02-14 12:58:00.948 INF audio: ( 3 ) Output Device : “Speakers (2- USB Audio CODEC )”
2024-02-14 12:58:00.948 INF default: Looking for inputs
2024-02-14 12:58:00.952 INF audio: "Client Audio input device CABLE Output (VB-Audio Virtual Cable) found! "
2024-02-14 12:58:00.952 INF default: Looking for outputs
2024-02-14 12:58:00.952 INF audio: "Client Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 12:58:00.956 INF audio: "Server Audio input device Microphone (2- USB Audio CODEC ) found! "
2024-02-14 12:58:00.956 INF audio: "Server Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 12:58:00.956 INF audio: Audio device(s) found (=default)
2024-02-14 12:58:00.956 INF audio: * ( 0 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2024-02-14 12:58:00.960 INF audio: ( 1 ) Input Device : “Microphone (2- USB Audio CODEC )”
2024-02-14 12:58:00.964 INF audio: * ( 0 ) Output Device : “Speakers / Headphones (Realtek Audio)”
2024-02-14 12:58:00.967 INF audio: ( 1 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2024-02-14 12:58:00.967 INF audio: ( 2 ) Output Device : “S271HL (Intel(R) Display Audio)”
2024-02-14 12:58:00.967 INF audio: ( 3 ) Output Device : “Speakers (2- USB Audio CODEC )”
2024-02-14 12:58:00.968 INF default: Looking for inputs
2024-02-14 12:58:00.968 INF audio: "Client Audio input device CABLE Output (VB-Audio Virtual Cable) found! "
2024-02-14 12:58:00.968 INF default: Looking for outputs
2024-02-14 12:58:00.968 INF audio: "Client Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 12:58:00.972 INF audio: "Server Audio input device Microphone (2- USB Audio CODEC ) found! "
2024-02-14 12:58:00.972 INF audio: "Server Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 13:04:54.293 INF audio: Audio device(s) found (=default)
2024-02-14 13:04:54.325 INF audio: * ( 0 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2024-02-14 13:04:54.325 INF audio: ( 1 ) Input Device : “Microphone (2- USB Audio CODEC )”
2024-02-14 13:04:54.657 INF audio: * ( 0 ) Output Device : “Headset Earphone (Plantronics Blackwire 3220 Series)”
2024-02-14 13:04:54.657 INF audio: ( 1 ) Output Device : “Speakers / Headphones (Realtek Audio)”
2024-02-14 13:04:54.657 INF audio: ( 2 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2024-02-14 13:04:54.657 INF audio: ( 3 ) Output Device : “S271HL (Intel(R) Display Audio)”
2024-02-14 13:04:54.657 INF audio: ( 4 ) Output Device : “Speakers (2- USB Audio CODEC )”
2024-02-14 13:04:54.657 INF default: Looking for inputs
2024-02-14 13:04:54.672 INF audio: "Client Audio input device CABLE Output (VB-Audio Virtual Cable) found! "
2024-02-14 13:04:54.672 INF default: Looking for outputs
2024-02-14 13:04:54.672 INF audio: "Client Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 13:04:54.679 INF audio: "Server Audio input device Microphone (2- USB Audio CODEC ) found! "
2024-02-14 13:04:54.679 INF audio: "Server Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 13:04:54.679 INF audio: Audio device(s) found (=default)
2024-02-14 13:04:54.695 INF audio: * ( 0 ) Input Device : “Headset Microphone (Plantronics Blackwire 3220 Series)”
2024-02-14 13:04:54.695 INF audio: ( 1 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2024-02-14 13:04:54.695 INF audio: ( 2 ) Input Device : “Microphone (2- USB Audio CODEC )”
2024-02-14 13:04:54.695 INF audio: * ( 0 ) Output Device : “Headset Earphone (Plantronics Blackwire 3220 Series)”
2024-02-14 13:04:54.695 INF audio: ( 1 ) Output Device : “Speakers / Headphones (Realtek Audio)”
2024-02-14 13:04:54.695 INF audio: ( 2 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2024-02-14 13:04:54.695 INF audio: ( 3 ) Output Device : “S271HL (Intel(R) Display Audio)”
2024-02-14 13:04:54.695 INF audio: ( 4 ) Output Device : “Speakers (2- USB Audio CODEC )”
2024-02-14 13:04:54.695 INF default: Looking for inputs
2024-02-14 13:04:54.695 INF audio: "Client Audio input device CABLE Output (VB-Audio Virtual Cable) found! "
2024-02-14 13:04:54.695 INF default: Looking for outputs
2024-02-14 13:04:54.695 INF audio: "Client Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 13:04:54.695 INF audio: "Server Audio input device Microphone (2- USB Audio CODEC ) found! "
2024-02-14 13:04:54.710 INF audio: "Server Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 13:04:54.710 INF audio: Audio device(s) found (=default)
2024-02-14 13:04:54.710 INF audio: * ( 0 ) Input Device : “Headset Microphone (Plantronics Blackwire 3220 Series)”
2024-02-14 13:04:54.710 INF audio: ( 1 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2024-02-14 13:04:54.710 INF audio: ( 2 ) Input Device : “Microphone (2- USB Audio CODEC )”
2024-02-14 13:04:54.710 INF audio: * ( 0 ) Output Device : “Headset Earphone (Plantronics Blackwire 3220 Series)”
2024-02-14 13:04:54.710 INF audio: ( 1 ) Output Device : “Speakers / Headphones (Realtek Audio)”
2024-02-14 13:04:54.710 INF audio: ( 2 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2024-02-14 13:04:54.710 INF audio: ( 3 ) Output Device : “S271HL (Intel(R) Display Audio)”
2024-02-14 13:04:54.710 INF audio: ( 4 ) Output Device : “Speakers (2- USB Audio CODEC )”
2024-02-14 13:04:54.710 INF default: Looking for inputs
2024-02-14 13:04:54.710 INF audio: "Client Audio input device CABLE Output (VB-Audio Virtual Cable) found! "
2024-02-14 13:04:54.710 INF default: Looking for outputs
2024-02-14 13:04:54.726 INF audio: "Client Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 13:04:54.726 INF audio: "Server Audio input device Microphone (2- USB Audio CODEC ) found! "
2024-02-14 13:04:54.726 INF audio: "Server Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 13:04:54.726 INF audio: Audio device(s) found (*=default)
2024-02-14 13:04:54.726 INF audio: * ( 0 ) Input Device : “Headset Microphone (Plantronics Blackwire 3220 Series)”
2024-02-14 13:04:54.726 INF audio: ( 1 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2024-02-14 13:04:54.726 INF audio: ( 2 ) Input Device : “Microphone (2- USB Audio CODEC )”
2024-02-14 13:04:54.726 INF audio: * ( 0 ) Output Device : “Headset Earphone (Plantronics Blackwire 3220 Series)”
2024-02-14 13:04:54.741 INF audio: ( 1 ) Output Device : “Speakers / Headphones (Realtek Audio)”
2024-02-14 13:04:54.741 INF audio: ( 2 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2024-02-14 13:04:54.741 INF audio: ( 3 ) Output Device : “S271HL (Intel(R) Display Audio)”
2024-02-14 13:04:54.757 INF audio: ( 4 ) Output Device : “Speakers (2- USB Audio CODEC )”
2024-02-14 13:04:54.757 INF default: Looking for inputs
2024-02-14 13:04:54.757 INF audio: "Client Audio input device CABLE Output (VB-Audio Virtual Cable) found! "
2024-02-14 13:04:54.757 INF default: Looking for outputs
2024-02-14 13:04:54.757 INF audio: "Client Audio output device Speakers / Headphones (Realtek Audio) found! "
2024-02-14 13:04:54.757 INF audio: "Server Audio input device Microphone (2- USB Audio CODEC ) found! "
2024-02-14 13:04:54.757 INF audio: "Server Audio output device Speakers / Headphones (Realtek Audio) found! "
