Icom 7100 - no voice
Hi Everyone,
This is my first post so please be patient.
I made server on WIN10 and client on Macbook (Sequoia 15.0.1).
Most of functions work perfect but there is no sound when transmitting and receiving.
Radio Access
→ Audio Output (I can choose between Speaker Macbook and VB-Cable)
→ Audio Input (the same)
Radio Settings
→ Modulations Input (I can choose between Mic, USB, ACC)
When I try to speak and transmitt only I hear my own voice on Macbook speaker.
I will be grateful for help where I am making a mistake ?
Best Regards,
Konrad SQ9KCP
For speaker and mic use, you do not need “VB-Cable”.
Simply select the microphone for the Audio Input and select the speaker for the Audio Output.
As for the modulation input on the radio, select USB if you are using the USB port (most likely so).
Let me know if this helps. There are more steps you can take once you have the basic setup complete.
Hi Elliot,
On client side I set like this:
Radio Access → Audio Output (speaker macbook)
→ Audio Output (mic macbook)
Radio Settings → Modulation Input (USB)
There was a little progress becuse I could transmit with voice and started to hear, unfortunately squelch was still “ON” even if I set 99%. radio noise was present. Finnally I found solutions :slight_smile:
Now working perfect.
Really appreciate your help.
Best Regards,
Konrad SQ9KCP
