Hi!
I think I’ve just run into an issue:
When I open the memories window all the memory entries are loaded fine from the device.
By default the memory group “00” is selected: when I select/recall e.g. the fifth entry the right frequency is set (e.g. “145.500”).
When now the memory group is changed to e.g. group “04” and I once more select/recall a certain item (e.g. “433.500”), it seems to me that the entry from the default group is taken (e.g. “145.500”) instead of the currently selected group.
I tested with the latest Windows nightly build (“wfview-master64-20250428–05-00-01.exe”) running on a PC which is connected (via network) to a Raspberry Pi (running on the latest master “wfserver version: 2.05 Git:124258e5”)
Best,
Lukas
