ICOM IC-7410 Wfview shuts down shortly after opening
Hello,
I’m using an ICOM IC-7410 on Windows 11 64, and version 1.62 of Wfview.
I opened the software and set the COM port and baud rate, closed down and now everytime I start up the program opens, then after around 5 seconds it closes.
Please find the debug file. As a new user I can’t attach files. Please let me know if you need any further information.
Many thanks.
Peter
2023-05-06 09:28:38.863 INF system: "wfview version: 1.62 (Git:3fa14eb on Mar 12 2023 at 15:51:31 by build@wfview.org). Operating System: Windows 11 Version 2009 (x86_64). Build Qt Version 6.3.2. Current Qt Version: 6.3.2"
2023-05-06 09:28:38.878 DBG system: Running with debugging options enabled.
2023-05-06 09:28:38.893 INF system: Loading settings from  "\\HKEY_CURRENT_USER\\Software\\wfview\\wfview"
2023-05-06 09:28:38.940 INF gui: Got Audio Output from Settings:  "Speakers (Realtek(R) Audio)"
2023-05-06 09:28:38.940 INF gui: Got Audio Input from Settings:  "Stereo Mix (Realtek(R) Audio)"
2023-05-06 09:28:38.972 INF cw: "Sidetone Output: Speakers (2- USB Audio CODEC ) (volume: 0 rate: 44100 type: 2"
2023-05-06 09:28:38.987 INF audio: Audio device(s) found (*=default)
2023-05-06 09:28:38.987 INF audio: * ( 0 ) Input Device :  "Microphone (2- USB Audio CODEC )"
2023-05-06 09:28:38.987 INF audio:   ( 1 ) Input Device :  "Stereo Mix (Realtek(R) Audio)"
2023-05-06 09:28:38.987 INF audio:   ( 2 ) Input Device :  "Microphone (Realtek(R) Audio)"
2023-05-06 09:28:38.987 INF audio: * ( 0 ) Output Device :  "Speakers (2- USB Audio CODEC )"
2023-05-06 09:28:38.987 INF audio:   ( 1 ) Output Device :  "Realtek Digital Output (Realtek(R) Audio)"
2023-05-06 09:28:38.987 INF audio:   ( 2 ) Output Device :  "5 - Q3279WG5B (AMD High Definition Audio Device)"
2023-05-06 09:28:38.987 INF audio:   ( 3 ) Output Device :  "Speakers (Realtek(R) Audio)"
2023-05-06 09:28:38.987 INF audio:   ( 4 ) Output Device :  "6 - Q3279WG5B (AMD High Definition Audio Device)"
2023-05-06 09:28:38.987 INF default: Looking for inputs
2023-05-06 09:28:38.987 INF audio: "Client Audio input device Stereo Mix (Realtek(R) Audio) found! "
2023-05-06 09:28:38.987 DBG gui: Changed audio input to: "Stereo Mix (Realtek(R) Audio)"
2023-05-06 09:28:38.987 INF default: Looking for outputs
2023-05-06 09:28:38.987 INF audio: "Client Audio output device Speakers (Realtek(R) Audio) found! "
2023-05-06 09:28:38.987 DBG gui: Changed audio output to: "Speakers (Realtek(R) Audio)"
2023-05-06 09:28:39.003 INF audio: "Server Audio input device Stereo Mix (Realtek(R) Audio) found! "
2023-05-06 09:28:39.003 INF audio: "Server Audio output device Speakers (Realtek(R) Audio) found! "
2023-05-06 09:28:39.003 DBG system: Audio devices done.
2023-05-06 09:28:39.003 DBG system: Running setUIToPrefs()
2023-05-06 09:28:39.110 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2023-05-06 09:28:39.110 DBG system: Running setInititalTiming()
2023-05-06 09:28:39.110 DBG system: Running openRig()
2023-05-06 09:28:39.110 INF rig: creating instance of rigCommander()
2023-05-06 09:28:39.110 DBG system: Running rigConnections()
2023-05-06 09:28:39.110 INF cluster: starting dxClusterClient()
2023-05-06 09:28:39.282 INF serial: Opened port:  "COM8"
2023-05-06 09:28:39.282 INF system: Received CommReady!!
2023-05-06 09:28:39.282 INF system: Delay command interval timing:  75 ms
2023-05-06 09:28:39.282 INF default: Setting rig state for wfmain
2023-05-06 09:28:39.282 DBG rig: Caught it! Found the echo'd broadcast request from us! Rig has not responded to broadcast query yet.
2023-05-06 09:28:39.298 DBG rigTraffic: Received from radio:
2023-05-06 09:28:39.298 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.298 DBG rigTraffic: "DATA:  19 00 80 fd "
2023-05-06 09:28:39.298 DBG rigTraffic: "INDEX: 00 01 02 03 "
2023-05-06 09:28:39.298 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.298 DBG rig: ---Rig FOUND from broadcast query:
2023-05-06 09:28:39.298 INF rig: Using incomingCIVAddr: (int):  128  hex:  "0x80"
2023-05-06 09:28:39.298 INF serial: Received rigCapabilities for "IC-7410"
2023-05-06 09:28:39.298 INF rig: Have rig ID: decimal:  128
2023-05-06 09:28:39.298 DBG system: Rig name:  "IC-7410"
2023-05-06 09:28:39.298 DBG system: Has LAN capabilities:  false
2023-05-06 09:28:39.298 DBG system: Rig ID received into wfmain: spectLenMax:  0
2023-05-06 09:28:39.298 DBG system: Rig ID received into wfmain: spectAmpMax:  0
2023-05-06 09:28:39.298 DBG system: Rig ID received into wfmain: spectSeqMax:  0
2023-05-06 09:28:39.298 DBG system: Rig ID received into wfmain: hasSpectrum:  false
2023-05-06 09:28:39.313 INF system: Delay command interval timing:  25 ms
2023-05-06 09:28:39.313 DBG default: Inserting 3 To slow queue, priority 128 len 0
2023-05-06 09:28:39.313 DBG default: Inserted 3 To slow queue, priority 128 len 1
2023-05-06 09:28:39.313 DBG default: Inserting 5 To slow queue, priority 128 len 1
2023-05-06 09:28:39.313 DBG default: Inserted 5 To slow queue, priority 128 len 2
2023-05-06 09:28:39.313 DBG default: Inserting 44 To slow queue, priority 128 len 2
2023-05-06 09:28:39.313 DBG default: Inserted 44 To slow queue, priority 128 len 3
2023-05-06 09:28:39.313 DBG default: Inserting 47 To slow queue, priority 128 len 3
2023-05-06 09:28:39.313 DBG default: Inserted 47 To slow queue, priority 128 len 4
2023-05-06 09:28:39.313 DBG default: Inserting 17 To slow queue, priority 128 len 4
2023-05-06 09:28:39.313 DBG default: Inserted 17 To slow queue, priority 128 len 5
2023-05-06 09:28:39.313 DBG default: Inserting 88 To slow queue, priority 128 len 5
2023-05-06 09:28:39.313 DBG default: Inserted 88 To slow queue, priority 128 len 6
2023-05-06 09:28:39.313 DBG default: Inserting 44 To slow queue, priority 128 len 6
2023-05-06 09:28:39.313 DBG default: Inserted 44 To slow queue, priority 128 len 7
2023-05-06 09:28:39.313 DBG default: Inserting 87 To slow queue, priority 128 len 7
2023-05-06 09:28:39.313 DBG default: Inserted 87 To slow queue, priority 128 len 8
2023-05-06 09:28:39.313 DBG default: Inserting 53 To slow queue, priority 128 len 8
2023-05-06 09:28:39.313 DBG default: Inserted 53 To slow queue, priority 128 len 9
2023-05-06 09:28:39.313 DBG default: Removing 62 From periodic queue, len 9
2023-05-06 09:28:39.313 DBG default: Removed 62 From periodic queue, len 9
2023-05-06 09:28:39.407 DBG rigTraffic: Final payload in rig commander to be sent to rig:
2023-05-06 09:28:39.407 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.407 DBG rigTraffic: "DATA:  fe fe 80 e1 03 fd "
2023-05-06 09:28:39.407 DBG rigTraffic: "INDEX: 00 01 02 03 04 05 "
2023-05-06 09:28:39.407 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.438 DBG rigTraffic: Received from radio:
2023-05-06 09:28:39.438 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.438 DBG rigTraffic: "DATA:  03 00 00 03 05 80 e1 15 02 fd "
2023-05-06 09:28:39.438 DBG rigTraffic: "INDEX: 00 01 02 03 04 05 06 07 08 09 "
2023-05-06 09:28:39.438 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.470 DBG rigTraffic: Final payload in rig commander to be sent to rig:
2023-05-06 09:28:39.470 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.470 DBG rigTraffic: "DATA:  fe fe 80 e1 04 fd "
2023-05-06 09:28:39.470 DBG rigTraffic: "INDEX: 00 01 02 03 04 05 "
2023-05-06 09:28:39.470 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.532 DBG rigTraffic: Final payload in rig commander to be sent to rig:
2023-05-06 09:28:39.532 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.532 DBG rigTraffic: "DATA:  fe fe 80 e1 03 fd "
2023-05-06 09:28:39.532 DBG rigTraffic: "INDEX: 00 01 02 03 04 05 "
2023-05-06 09:28:39.532 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.548 DBG rigTraffic: Received from radio:
2023-05-06 09:28:39.548 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.548 DBG rigTraffic: "DATA:  03 00 00 03 15 00 fd "
2023-05-06 09:28:39.548 DBG rigTraffic: "INDEX: 00 01 02 03 04 05 06 "
2023-05-06 09:28:39.548 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.595 DBG rigTraffic: Final payload in rig commander to be sent to rig:
2023-05-06 09:28:39.595 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.595 DBG rigTraffic: "DATA:  fe fe 80 e1 04 fd "
2023-05-06 09:28:39.595 DBG rigTraffic: "INDEX: 00 01 02 03 04 05 "
2023-05-06 09:28:39.595 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.610 DBG rigTraffic: Received from radio:
2023-05-06 09:28:39.610 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.610 DBG rigTraffic: "DATA:  04 05 01 fd "
2023-05-06 09:28:39.610 DBG rigTraffic: "INDEX: 00 01 02 03 "
2023-05-06 09:28:39.610 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.610 DBG default: Removing 29 From periodic queue, len 9
2023-05-06 09:28:39.610 DBG default: Removed 29 From periodic queue, len 9
2023-05-06 09:28:39.610 DBG default: Removing 25 From periodic queue, len 9
2023-05-06 09:28:39.610 DBG default: Removed 25 From periodic queue, len 9
2023-05-06 09:28:39.610 DBG default: Removing 27 From periodic queue, len 9
2023-05-06 09:28:39.610 DBG default: Removed 27 From periodic queue, len 9
2023-05-06 09:28:39.720 DBG rigTraffic: Final payload in rig commander to be sent to rig:
2023-05-06 09:28:39.720 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.720 DBG rigTraffic: "DATA:  fe fe 80 e1 03 fd "
2023-05-06 09:28:39.720 DBG rigTraffic: "INDEX: 00 01 02 03 04 05 "
2023-05-06 09:28:39.720 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.735 DBG rigTraffic: Received from radio:
2023-05-06 09:28:39.735 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.735 DBG rigTraffic: "DATA:  03 00 00 03 15 00 fd "
2023-05-06 09:28:39.735 DBG rigTraffic: "INDEX: 00 01 02 03 04 05 06 "
2023-05-06 09:28:39.735 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.782 DBG rigTraffic: Final payload in rig commander to be sent to rig:
2023-05-06 09:28:39.782 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.782 DBG rigTraffic: "DATA:  fe fe 80 e1 04 fd "
2023-05-06 09:28:39.782 DBG rigTraffic: "INDEX: 00 01 02 03 04 05 "
2023-05-06 09:28:39.782 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.798 DBG rigTraffic: Received from radio:
2023-05-06 09:28:39.798 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.798 DBG rigTraffic: "DATA:  04 05 01 fd "
2023-05-06 09:28:39.798 DBG rigTraffic: "INDEX: 00 01 02 03 "
2023-05-06 09:28:39.798 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.845 DBG rigTraffic: Final payload in rig commander to be sent to rig:
2023-05-06 09:28:39.845 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.845 DBG rigTraffic: "DATA:  fe fe 80 e1 1a 06 fd "
2023-05-06 09:28:39.845 DBG rigTraffic: "INDEX: 00 01 02 03 04 05 06 "
2023-05-06 09:28:39.845 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.860 DBG rigTraffic: Received from radio:
2023-05-06 09:28:39.860 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.860 DBG rigTraffic: "DATA:  1a 06 00 00 fd "
2023-05-06 09:28:39.860 DBG rigTraffic: "INDEX: 00 01 02 03 04 "
2023-05-06 09:28:39.860 DBG rigTraffic: "----  End hex dump  -----"
2023-05-06 09:28:39.907 DBG rigTraffic: Final payload in rig commander to be sent to rig:
2023-05-06 09:28:39.907 DBG rigTraffic: "---- Begin hex dump -----:"
2023-05-06 09:28:39.907 DBG rigTraffic: "DATA:  fe fe 80 e1 fd "
2023-05-06 09:28:39.907 DBG rigTraffic: "INDEX: 00 01 02 03 04 "
2023-05-06 09:28:39.907 DBG rigTraffic: "----  End hex dump  -----"
Seems to be resolved by installing the 32bit version. Would be nice to be able to use the 64bit version at some point. Thanks
Did you install the right icom drivers before you connected it to your windows 11 system?
And generally I think that using 32 bit is not the solution.
Hi, yes I did. V 1.3. I noticed there were similar issues reported.
Hi Peter.
That reply of mine has nothing to do with a possible 32/64 bit issue and was regarding adding manually keyed CW.
The vast majority of Windows users are successfully using the 64bit version and I have never been able to replicate this issue (so far we have only received 2 reports including yours)
The main difference between the 32bit and 64bit versions of wfview, is the version of the underlying framework (Qt) that we use. In the 64bit version, we are using Qt6, it is likely that your machine has some incompatibility with this version of Qt, but it is almost impossible to say what/where.
The next release of wfview will use a newer version of Qt6 so it is worth waiting for that and try the 64bit version again.
Thanks for the clarification Phil
I tested on another W11 machine (this time a laptop) and had exactly the same experience.
In both cases if I run without the USB cable connected it does not crash.
Will test the next version as you suggest.
Peter 2E0LRZ
I’m not sure if these logs from Event Viewer help Phil?
Faulting application name: wfview.exe, version: 0.0.0.0, time stamp: 0x640df66d
Faulting module name: wfview.exe, version: 0.0.0.0, time stamp: 0x640df66d
Exception code: 0xc0000005
Fault offset: 0x00000000000c2444
Faulting process ID: 0x0x1648
Faulting application start time: 0x0x1D97FF77F7B1F50
Faulting application path: C:\Program Files\wfview\wfview.exe
Faulting module path: C:\Program Files\wfview\wfview.exe
Report ID: 19cf7dd6-f59b-496f-9be6-d0cf05b1c8fc
Faulting package full name:
Faulting package-relative application ID:
I tried this afternoon on a fresh install of W11 with my ICOM 7410 again and had the same issue. With the radio not attached the program does not crash.
I’m happy with the 32bit version, so just providing these logs for information and will try the next update when available.
Thanks for your work on this great project! It’s fantastic.
