Software installed fine and ran up until I configured it and pointed it to the server. Now it crashes within a second of running it. Deleting and reinstalling doesn’t work as it seems to retain the original configuration.
I was running version 11. Upgraded to version 15 with the same results. I also noticed if I hit the radio power button on the wfview before it crashes the software will run for a little bit but eventually crash anyways.
I had the exact same failure with crash on Intel MBP with MacOS 15.2. If you don’t connect to the remote server it stays up and you can goto “log” and “show path”.
With Teminal “cd” to that path and read the old log. I had “buffer overruns” which went away by choosing QT audio system.
