Hi
Cant seem to install on the above Mac OS throws an error. Is this version just too old or should it work.
Many Thanks
Simon
It should work, knowing what the error message was would be useful though
Hi Phil
Thanks for swift response.
Error report attached…
Trying to update it to Catalina but seem to be struggling be good if it would work with existing OS version
Many Thanks
Simon
(Attachment Error Report.docx is missing)
We don’t support word documents as attachments, can you try sending a screenshot (.png/jpg) image?
Text below hopefully that is ok
Cheers
Process: wfview [2908]
Path: /private/var/folders/*/wfview.app/Contents/MacOS/wfview
Identifier: org.wfview.wfview
Version: 0
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: wfview [2908]
User ID: 501
Date/Time: 2023-04-18 16:58:28.126 +0100
OS Version: Mac OS X 10.14.6 (18G9323)
Report Version: 12
Anonymous UUID: 2F4BF65E-B6FE-8CCB-6564-6C3F4DFC1095
Sleep/Wake UUID: BF0834A8-0B7F-46E5-8E93-B48D232BB7B8
Time Awake Since Boot: 9800 seconds
Time Since Wake: 2000 seconds
System Integrity Protection: enabled
Notes: Translocated Process
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @executable_path/…/Frameworks/libhidapi.0.dylib
Referenced from: /private/var/folders/*/wfview.app/Contents/MacOS/wfview
Reason: no suitable image found. Did find:
/private/var/folders/_b/ms1qym3131l66z7n9r6tlrp40000gn/T/AppTranslocation/B2D653AF-55DB-4455-BF0A-EA7BDBF0255C/d/wfview.app/Contents/MacOS/…/Frameworks/libhidapi.0.dylib: cannot load ‘libhidapi.0.dylib’ (load command 0x80000034 is unknown)
/private/var/folders/_b/ms1qym3131l66z7n9r6tlrp40000gn/T/AppTranslocation/B2D653AF-55DB-4455-BF0A-EA7BDBF0255C/d/wfview.app/Contents/MacOS/…/Frameworks/libhidapi.0.dylib: stat() failed with errno=45
Binary Images:
0x1044df000 - 0x10484aff3 +org.wfview.wfview (0) /var/folders/*/wfview.app/Contents/MacOS/wfview
0x1048c4000 - 0x1048d7ff7 +libportaudio.2.dylib (3) <437849FD-082A-3B1B-AF70-9EDCF0507782> /var/folders/*/wfview.app/Contents/Frameworks/libportaudio.2.dylib
0x1118f9000 - 0x11196370f dyld (655.1.1) <4842B61A-B868-3146-9CA9-5582C4198B25> /usr/lib/dyld
0x7fff46268000 - 0x7fff462eefff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff467f4000 - 0x7fff46c3afff com.apple.CoreFoundation (6.9 - 1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff6f900000 - 0x7fff6f901ffb libSystem.B.dylib (1252.250.1) /usr/lib/libSystem.B.dylib
Model: MacBookAir6,1, BootROM 431.140.6.0.0, 2 processors, Intel Core i7, 1.7 GHz, 4 GB, SMC 2.12f143
Graphics: kHW_IntelHD5000Item, Intel HD Graphics 5000, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3230554638454455302D474E2D4620
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3230554638454455302D474E2D4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x117), Broadcom BCM43xx 1.0 (7.77.61.3 AirPortDriverBrcmNIC-1305.12)
Bluetooth: Version 6.0.14d13, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SD0256F, 251 GB
USB Device: USB 3.0 Bus
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Air, Apple Inc., 23.6
In the latest 1.6x releases of wfview, we have moved to Qt6 which requires a minimum of MacOS 11 (BigSur). Official support for Mojave ended in 2021.
You can try installing an older version from https://wfview.org/older-downloads/ but if possible I would recommend upgrading your OS (any mac model from 2013 or later ‘should’ take BigSur)
Many thanks Phil
Will keep trying on the laptop. It is a macbook AIR not sure of its age but I believe 2015
Cheers
Simon
If it’s a 2015 model MacBook Air, it can run Monterey, Ventura requires 2018 or newer and BigSur requires 2013 or newer. You can easily find what model year it is from ‘About this Mac’
Managed to get big sur on it in the end and now up and running.
Great software.
BR
Simon
