I am running W10 and received this error during the installation.
Thanks! Does the ICOM 7610 pass civ commands via USB? My Civ cable is attached to a SteppIR controller.
Brad
BRAD have you ever seen wfview on your 7610 and wfview?
i cannot to see the radio.
win10 and icom 7610: what do i need to do? i have 1.5
I don’t understand your questions. How can you see the radio?
Brad
Hi Brad,
For the IC-7610, you will get the best experience using ethernet for wfview. This requires the CI-V baud rate being set to 115200. I believe the “remote” CI-V port can still be at 19200. @Roeland can tell you for sure as he has a similar setup.
Instead of ethernet, you could use the USB cable instead. Using the USB cable will produce a much slower waterfall though (this is just how the data are sent from the rig).
Yeah, I use the Ethernet option, and it works fine. I have tried the USB but it is slower and not as reliable IMO…
