Just seeing if anyone has noticed this problem. I just installed “Andy’s Ham Radio Linux” on my laptop. I got it running well, but I find that the older version of WFView is 1.2e that is installed. When I run the installer script, it all starts up fine but then it totally locks up after a few minutes and computer needs to do a forced shutdown since it’s totally locked up.
Has anyone tried this? The distro uses Xubuntu and has a lot of good radio stuff pre-installled, and wanting to try this out. 1.2e will work fine, but I want to keep all the software updated obviously.
I think he is trying to install the latest version. I recommend this over the 1.5 binary release. The binary releases sometimes have odd compatibility issues which are difficult to diagnose. Plus we are on version 1.53 now :-).
The computer is a Dell i7 with 4Gb of memory. It’s an older EliteBook 8540W. Yeah, I should get a new one eventually, but just one of my laptops I have lying around. I usually play with Linux on them so horsepower hasn’t been much of an issue vs. Windows!
I run WFview flawlessly on a Raspberry Pi 4 and 400, and also got it running fine on one of those $30 Quadra computers. I do upgrade often using the install script and keep my PI’s on the latest version.
I’ll run the install again and capture a screenshot of where it locks up.
Tom
Running it again. It’s still going. I’m running from my other machine through SSH so I can see what’s happening. I wonder if the power save on the laptop killed it off? I changed the settings this time.
It’s taking a LONG time, and still hear the drive running so it’s working on something. Strange that a Pi or other wimpy little computer just takes a few minutes.
When trying yesterday, I did have a second SSH connection to monitor the processes using ‘top’. It went up to 8 on the load, so it was working hard at something.
You may want to try forcing it to use only one CPU core during the compile. I have seen some computers either run out of ram or overexert their power supply and die on big builds.
The change to the script is a single line (approximately line 159, depending upon how fresh your script is):
The text that says: time make -j2
Should be changed to: time make
That may do the trick. It’ll take a while but it should come out ok.
I have a Core2 Duo with 3 GB of ram in my kitchen, with linux mint. I use the blackbox window manager, which uses only 3 MB of ram. It runs wfview fine and it’s one of my favorite test machines. But compiling is not fast! System updates are basically an excuse to grab a coffee and walk a mile around the neighborhood.
Boom!
That did the trick. 1.53 installed in just a few very short minutes. I’ll have to remember this fix somewhere since I’m always playing with different Linux distros.
Thanks Elliott, I hope this helps others that may run into this challenge.
73, KA7VIK
(thanks for the work on this software, I’ve said a few times already how much I like it).
