Hello,
I’m using Wfview with an R8600, 9700 and 7610.
With the 9700 when switching band, the app actually switches the band but the 9700 comes back to the previous frequency. For instance let’s say the VFO A on Main VFO is 145.000 and I’m switching to 70cm, then the app show 432.000; the 9700 goes to 432.00 and revert within a second to 145.000 whereas the app is still at 432.000.
Is there a settings I’m missing or is it a bug ?
I’ve tested both in USB and Ethernet and the behavior is the same. Don’t have any other running program controlling the radio. This happens only with 70cm band
Here is a video showing the effect :
I have never seen that with the IC9700, so I suspect it is an issue with your BSR (band stacking register). All the wfview band buttons do is tell the radio to switch to a particular band using the BSR.
It is possible that your 70cm BSR is actually stuck on 2m, can you try selecting the 70cm band then manually change frequency to within the 70cm band?
I’m using Windows 10 on 2 machines (local in USB) and remotely via ethernet with Wfview 1.64.
I’ve passed by the station during lunch time and found out that actually the issue is probably with the IC9700. The IC9700 is apparently not able to have both MAIN and SUB VFOs in the same band (Full duplex). So that the BSR of the MAIN VFO shows the band active in SUB VFO as grayed…
For instance
MAIN VFOA is 2m
SUB VFOA is 70cm
then unable to set MAIN VFOA on 70cm
or
MAIN VFOA is 70cm
SUB VFOA is 23cm
then unable to set MAIN VFOA on 23cm
As Wfview 1.64 manage only one VFO this is then impossible to switch between the active band on the MAIN VFO to the one which is already enabled on the SUB VFO.
This is maybe solved in the version 2.0 with DUAL VFO support ?
