i am trying to use my ic-7300 in local lan, but get the message"searching CI-V bus for connected radios". Get no connection - where do I start to find the solution ?
Your might like to read Elliott post here on Remote control when away from home - #7 by eliggett.
PK
Did you ever solve this problem? Having the same issue with IC-705.
did you read the suggested link?
you might tell more about what you experience together with your setup. My 705 works.
