E,
Here you go!
vr,
Kevin, WA6JKKN
https://termbin.com/xsbvw
2023-02-15 17:35:09.316 INF system: “wfview version: 1.61 (Git:b373685 on Feb 7 2023 at 20:18:52 by build@wfview.org). Operating System: Windows 10 Version 2009 (x86_64). Build Qt Version 6.3.2. Current Qt Version: 6.3.2”
2023-02-15 17:35:09.363 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2023-02-15 17:35:09.394 INF gui: Got Audio Output from Settings: “Speakers (Realtek High Definition Audio)”
2023-02-15 17:35:09.394 INF gui: Got Audio Input from Settings: “Microphone (2- USB Audio CODEC )”
2023-02-15 17:35:09.461 INF audio: Audio device(s) found (*=default)
2023-02-15 17:35:09.492 INF audio: * ( 0 ) Input Device : “Microphone (2- USB Audio CODEC )”
2023-02-15 17:35:09.492 INF audio: ( 1 ) Input Device : “Line (AMM-HFSD-1 Mod Monitor)”
2023-02-15 17:35:09.507 INF audio: * ( 0 ) Output Device : “Speakers (Realtek High Definition Audio)”
2023-02-15 17:35:09.507 INF audio: ( 1 ) Output Device : “Speakers (NoMachine Microphone Adapter)”
2023-02-15 17:35:09.507 INF audio: ( 2 ) Output Device : “Speakers (2- USB Audio CODEC )”
2023-02-15 17:35:09.507 INF default: Looking for inputs
2023-02-15 17:35:09.507 INF audio: "Client Audio input device Microphone (2- USB Audio CODEC ) found! "
2023-02-15 17:35:09.507 INF default: Looking for outputs
2023-02-15 17:35:09.507 INF audio: "Client Audio output device Speakers (Realtek High Definition Audio) found! "
2023-02-15 17:35:09.507 INF audio: "Server Audio input device Microphone (2- USB Audio CODEC ) found! "
2023-02-15 17:35:09.507 INF audio: "Server Audio output device Speakers (2- USB Audio CODEC ) found! "
2023-02-15 17:35:09.711 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2023-02-15 17:35:09.711 INF rig: creating instance of rigCommander()
2023-02-15 17:35:09.711 INF udp: Starting udpHandler user: “Kevin” rx latency: 120 tx latency: 120 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2023-02-15 17:35:09.711 INF cluster: starting dxClusterClient()
2023-02-15 17:35:09.748 INF udp: Got IP Address : “wa6jkn7610.hopto.org” : “174.85.93.115”
2023-02-15 17:35:09.748 INF udp: UDP Stream bound to local port: 65357 remote port: 50011
2023-02-15 17:35:09.780 INF system: Received CommReady!!
2023-02-15 17:35:09.780 INF default: Setting rig state for wfmain
2023-02-15 17:35:10.242 INF udp: udpHandler : Received I am here from: QHostAddress(“::ffff:174.85.93.115”)
2023-02-15 17:35:10.242 INF udp: udpHandler : Received I am ready
2023-02-15 17:35:10.242 INF udp: udpHandler : Sending login packet
2023-02-15 17:35:10.242 INF udp: Got connection type: “FTTH”
2023-02-15 17:35:10.242 INF udp: udpHandler : Received matching token response to our request
2023-02-15 17:35:10.242 INF udp: udpHandler : Detected connection speed FTTH
2023-02-15 17:35:10.258 INF udp: udpHandler “Received radio capabilities, Name: IC-7610, Audio: ICOM_VAUDIO, CIV: 98, MAC: 00:90:c7:09:7e:76 CAPF: 5001”
2023-02-15 17:35:10.258 INF udp: Got Connection status for: IC-7610 Busy: 0 Computer IP “0.0.0.0”
2023-02-15 17:35:10.258 INF udp: Got Radio 0
2023-02-15 17:35:10.258 INF udp: Find available local ports
2023-02-15 17:35:10.258 INF default: Received serial port baud rate from remote server: 19200
2023-02-15 17:35:10.258 INF system: Delay command interval timing: 75 ms
2023-02-15 17:35:10.258 INF udp: Starting udpCivData
2023-02-15 17:35:10.258 INF udp: UDP Stream bound to local port: 65358 remote port: 50012
2023-02-15 17:35:10.258 INF udp: Starting udpAudio
2023-02-15 17:35:10.258 INF udp: UDP Stream bound to local port: 65359 remote port: 50013
2023-02-15 17:35:10.258 INF udp: udpHandler Got serial and audio request success, device name: “IC-7610”
2023-02-15 17:35:10.258 INF udp: Got Connection status for: IC-7610 Busy: 1 Computer DESKTOP–wfview IP “174.85.93.115”
2023-02-15 17:35:10.258 INF audio: Output audio handler starting: “Speakers (Realtek High Definition Audio)”
2023-02-15 17:35:10.258 INF audio: Input audio handler starting: “Microphone (2- USB Audio CODEC )”
2023-02-15 17:35:10.258 INF udp: udpCivData : Received I am here
2023-02-15 17:35:10.258 INF audio: Input thread id 0xd94c
2023-02-15 17:35:10.258 INF audio: Input start() running
2023-02-15 17:35:10.258 INF udp: udpAudio : Received I am here
2023-02-15 17:35:10.273 INF audioconverter: Starting audioConverter() Input: 2 Channels of 0 48000 Int16 Output: 1 Channels of 0 48000 Int16
2023-02-15 17:35:10.273 INF audio: Output thread id 0xbd88
2023-02-15 17:35:10.273 INF audio: Output start() running
2023-02-15 17:35:10.273 INF audioconverter: Starting audioConverter() Input: 1 Channels of 0 48000 Int16 Output: 2 Channels of 0 48000 Int16
2023-02-15 17:35:10.431 INF rig: Using incomingCIVAddr: (int): 152 hex: “0x98”
2023-02-15 17:35:10.431 INF serial: Received rigCapabilities for “IC-7610”
2023-02-15 17:35:10.431 INF rig: Have rig ID: decimal: 152
2023-02-15 17:35:10.432 INF system: Delay command interval timing: 25 ms
2023-02-15 17:35:11.252 INF system: Could not find modulation input: 4
2023-02-15 17:36:02.400 INF audioconverter: Closing audioConverter() Input: 1 Channels of 0 48000 Int16 Output: 2 Channels of 0 48000 Int16
2023-02-15 17:36:02.428 INF audioconverter: Closing audioConverter() Input: 2 Channels of 0 48000 Int16 Output: 1 Channels of 0 48000 Int16
2023-02-15 17:36:02.443 INF udp: Closing UDP stream : “174.85.93.115” : 50013
2023-02-15 17:36:02.443 INF udp: Closing UDP stream : “174.85.93.115” : 50012
2023-02-15 17:36:02.443 INF udp: Sending token removal packet
2023-02-15 17:36:02.443 INF udp: Closing UDP stream : “174.85.93.115” : 50011
2023-02-15 17:36:03.170 INF udp: Starting udpHandler user: “Kevin” rx latency: 120 tx latency: 120 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2023-02-15 17:36:03.170 INF udp: Got IP Address : “wa6jkn7610.hopto.org” : “174.85.93.115”
2023-02-15 17:36:03.170 INF system: Received CommReady!!
2023-02-15 17:36:03.170 INF default: Setting rig state for wfmain
2023-02-15 17:36:03.170 INF udp: UDP Stream bound to local port: 54148 remote port: 50011
2023-02-15 17:36:03.682 INF udp: udpHandler : Received I am here from: QHostAddress(“::ffff:174.85.93.115”)
2023-02-15 17:36:03.682 INF udp: udpHandler : Received I am ready
2023-02-15 17:36:03.682 INF udp: udpHandler : Sending login packet
2023-02-15 17:36:03.682 INF udp: Got connection type: “FTTH”
2023-02-15 17:36:03.682 INF udp: udpHandler : Received matching token response to our request
2023-02-15 17:36:03.682 INF udp: udpHandler : Detected connection speed FTTH
2023-02-15 17:36:03.697 INF udp: udpHandler “Received radio capabilities, Name: IC-7610, Audio: ICOM_VAUDIO, CIV: 98, MAC: 00:90:c7:09:7e:76 CAPF: 5001”
2023-02-15 17:36:03.697 INF udp: Got Connection status for: IC-7610 Busy: 0 Computer IP “0.0.0.0”
2023-02-15 17:36:03.697 INF udp: Got Radio 0
2023-02-15 17:36:03.697 INF udp: Find available local ports
2023-02-15 17:36:03.697 INF default: Received serial port baud rate from remote server: 19200
2023-02-15 17:36:03.697 INF system: Delay command interval timing: 75 ms
2023-02-15 17:36:03.697 INF udp: Starting udpCivData
2023-02-15 17:36:03.697 INF udp: UDP Stream bound to local port: 54149 remote port: 50012
2023-02-15 17:36:03.697 INF udp: Starting udpAudio
2023-02-15 17:36:03.697 INF udp: UDP Stream bound to local port: 54150 remote port: 50013
2023-02-15 17:36:03.697 INF udp: udpHandler Got serial and audio request success, device name: “IC-7610”
2023-02-15 17:36:03.697 INF udp: Got Connection status for: IC-7610 Busy: 1 Computer DESKTOP–wfview IP “174.85.93.115”
2023-02-15 17:36:03.697 INF audio: Output audio handler starting: “Speakers (Realtek High Definition Audio)”
2023-02-15 17:36:03.713 INF audio: Input audio handler starting: “Microphone (2- USB Audio CODEC )”
2023-02-15 17:36:03.713 INF audio: Input thread id 0x58f0
2023-02-15 17:36:03.713 INF audio: Output thread id 0xe614
2023-02-15 17:36:03.713 INF audio: Output start() running
2023-02-15 17:36:03.713 INF udp: udpCivData : Received I am here
2023-02-15 17:36:03.713 INF audio: Input start() running
2023-02-15 17:36:03.713 INF udp: udpAudio : Received I am here
2023-02-15 17:36:03.713 INF audioconverter: Starting audioConverter() Input: 1 Channels of 0 48000 Int16 Output: 2 Channels of 0 48000 Int16
2023-02-15 17:36:03.713 INF audioconverter: Starting audioConverter() Input: 2 Channels of 0 48000 Int16 Output: 1 Channels of 0 48000 Int16
2023-02-15 17:36:03.786 INF rig: Using incomingCIVAddr: (int): 152 hex: “0x98”
2023-02-15 17:36:03.786 INF serial: Received rigCapabilities for “IC-7610”
2023-02-15 17:36:03.786 INF rig: Have rig ID: decimal: 152
2023-02-15 17:36:03.787 INF system: Delay command interval timing: 25 ms
2023-02-15 17:36:04.430 INF system: Could not find modulation input: 4
2023-02-15 17:36:05.108 INF system: Could not find modulation input: 4
2023-02-15 17:37:08.123 INF udp: udpCivData : sending request for missing packet : “0x1717”
2023-02-15 17:37:17.533 INF udp: udpCivData : sending request for missing packet : “0x1a72”
2023-02-15 17:39:36.717 INF udp: Audio Watchdog: no audio data received for 2s, restart required?
2023-02-15 17:39:36.717 INF audioconverter: Closing audioConverter() Input: 1 Channels of 0 48000 Int16 Output: 2 Channels of 0 48000 Int16
2023-02-15 17:39:36.736 INF audioconverter: Closing audioConverter() Input: 2 Channels of 0 48000 Int16 Output: 1 Channels of 0 48000 Int16
2023-02-15 17:39:36.751 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2023-02-15 17:40:40.712 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2023-02-15 17:41:03.678 WRN default: udpHandler : Radio rejected token renewal, performing login
2023-02-15 17:41:03.678 INF udp: udpHandler : Connection failed, wait a few minutes or reboot the radio.
2023-02-15 17:41:03.678 INF rig: Error using port “174.85.93.115” message: “Connection failed\ntry rebooting the radio.”
2023-02-15 17:41:03.678 INF udp: Closing UDP stream : “174.85.93.115” : 50011
2023-02-15 17:47:56.278 INF log: Sending data to termbin.com. Standby.
2023-02-15 17:47:56.484 INF log: Connected to logging host
2023-02-15 17:48:01.866 INF log: Receiving data from logging host.
2023-02-15 17:48:01.866 INF log: Sent log to URL: “https://termbin.com/xsbvw\n\u0000”
2023-02-15 17:48:01.866 INF log: This address already copied to the clipboard. Please paste this URL in to your support questions.
2023-02-15 17:48:01.886 INF log: Disconnected from logging host
