Librtaudio6
  1. Operating System: Raspberry Pi OS Trixie
  2. Method of download attempted (from wfview.org):
  3. Radio Make and Model: FT-710
  4. Method of radio connectivity (USB):
  5. Did you check the FAQ and read the manual? Yes
Trying to install WFView on Raspberry Pi 400 with a fresh install of Trixie. Downloaded the script to the downloads folder. Ran the two commands to install. When installing the dependencies, I get the following:
E: unable to locate package
The installation stops there. Any suggestions?
Try this to track it down:
Remove any “version numbers” and search your repo:
apt-cache search librtaudio
And then if you find a package that looks correct:
sudo apt install librtaudio6 librtaudio6-dev
(or whatever the titles are that you find).
If you don’t mind, report back to us what you discover.
Elliott Thanks here is what i get:
ok, sounds like you’re good to go.
Remove the line in the script that installs this particular dependency and then run it again. Do this each time you run into something.
