- Operating System:
“Andy’s Ham Radio Linux” 22.04.3 LTS (Jammy Jellyfish) - Method of download attempted (from wfview.org, package manager, source code, etc):
Installed from .sh script – Wfview 1.64 - Radio Model:
Icom 7300 - Method of radio connectivity (USB, WiFi, Ethernet, etc):
USB - Did you check the FAQ and read the manual?
Yes - all correct worked fine before newer distro of “Andy’s”
I have been using “Andy’s Ham Radio Linux” on my PC for a while and have had great results with Wfview. I recently cleared and installed the newest version “v25a” which has a few new things and updates.
Now I keep getting the “could not open port. Please restart” message. I can get the radio to connect, when turn on the 7300, move the usb to a different port and then the radio seems to connect. I still haven’t figured out the sequence since it will shut off / on remotely then (most of the time). Sometimes still won’t connect until I do it again.
I used to be able to reboot the computer an have it all work and connect fine with no problems. Just when I updated my OS I’ve had this problem now. Maybe I need to go back a version? But would like to use some of the new features installed.
It’s saying ttyUSB0 is the problem. I do try deleting the /dev/usbTTY0 (or the long file link in /dev/serial/by-id/…" and it comes back with the same thing.
I know that the “Brttly” software has taken the port in the past, but I learned from that and always remove that if install on any PC/Pi on the radio that I use.
LSUSB shows this:
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 003: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Bus 001 Device 006: ID 08bb:2901 Texas Instruments PCM2901 Audio Codec
Bus 001 Device 004: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
Bus 001 Device 002: ID 0451:2046 Texas Instruments, Inc. TUSB2046 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
and this…
sudo dmesg | grep tty
[sudo] password for tegwilym:
[ 0.097783] printk: console [tty0] enabled
[ 0.481981] 00:01: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 15.641019] usb 1-7.1: cp210x converter now attached to ttyUSB0
Any ideas what I got screwed up?
Thanks!
73 ,KA7ViK
