now using W11 WFview v2.03
and yes I have the same log messages but my computer has decided to change the pasted text color to unreadable yellowβ¦
2025-02-25 13:49:20.993 WRN rig: β---- End hex dump -----β
2025-02-25 13:49:31.652 INF default: βData: 0 Input: M/A current: M/Aβ
2025-02-25 13:49:36.940 INF default: βData: 1 Input: USB current: USBβ
2025-02-25 13:49:41.305 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:49:41.305 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:49:41.305 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:49:41.305 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:49:41.305 WRN rig: β---- End hex dump -----β
2025-02-25 13:50:02.438 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:50:02.438 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:50:02.438 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:50:02.438 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:50:02.438 WRN rig: β---- End hex dump -----β
2025-02-25 13:50:20.313 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:50:20.313 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:50:20.313 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:50:20.314 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:50:20.314 WRN rig: β---- End hex dump -----β
2025-02-25 13:50:38.188 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:50:38.188 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:50:38.188 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:50:38.188 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:50:38.188 WRN rig: β---- End hex dump -----β
2025-02-25 13:50:56.064 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:50:56.064 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:50:56.064 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:50:56.064 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:50:56.064 WRN rig: β---- End hex dump -----β
2025-02-25 13:51:15.971 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:51:15.971 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:51:15.971 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:51:15.971 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:51:15.971 WRN rig: β---- End hex dump -----β
2025-02-25 13:51:37.294 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:51:37.295 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:51:37.295 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:51:37.295 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:51:37.295 WRN rig: β---- End hex dump -----β
2025-02-25 13:51:57.615 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:51:57.615 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:51:57.615 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:51:57.615 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:51:57.615 WRN rig: β---- End hex dump -----β
2025-02-25 13:52:15.504 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:52:15.504 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:52:15.504 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:52:15.505 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:52:15.505 WRN rig: β---- End hex dump -----β
2025-02-25 13:52:35.588 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:52:35.589 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:52:35.589 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:52:35.589 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:52:35.589 WRN rig: β---- End hex dump -----β
2025-02-25 13:52:53.459 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:52:53.459 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:52:53.459 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:52:53.459 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:52:53.459 WRN rig: β---- End hex dump -----β
2025-02-25 13:53:11.337 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:53:11.337 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:53:11.337 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:53:11.338 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:53:11.338 WRN rig: β---- End hex dump -----β
2025-02-25 13:53:29.207 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:53:29.207 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:53:29.207 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:53:29.207 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:53:29.207 WRN rig: β---- End hex dump -----β
2025-02-25 13:53:47.080 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:53:47.080 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:53:47.080 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:53:47.080 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:53:47.081 WRN rig: β---- End hex dump -----β
2025-02-25 13:54:04.955 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:54:04.955 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:54:04.955 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:54:04.955 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:54:04.955 WRN rig: β---- End hex dump -----β
2025-02-25 13:54:22.804 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:54:22.804 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:54:22.804 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:54:22.805 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:54:22.805 WRN rig: β---- End hex dump -----β
2025-02-25 13:54:40.681 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:54:40.681 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:54:40.681 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:54:40.681 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:54:40.681 WRN rig: β---- End hex dump -----β
2025-02-25 13:54:58.550 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:54:58.550 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:54:58.550 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:54:58.550 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:54:58.550 WRN rig: β---- End hex dump -----β
2025-02-25 13:55:16.412 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:55:16.412 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:55:16.412 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:55:16.412 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:55:16.412 WRN rig: β---- End hex dump -----β
2025-02-25 13:55:34.294 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:55:34.294 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:55:34.294 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:55:34.294 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:55:34.294 WRN rig: β---- End hex dump -----β
2025-02-25 13:55:52.160 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:55:52.161 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:55:52.161 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:55:52.161 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:55:52.161 WRN rig: β---- End hex dump -----β
2025-02-25 13:56:10.031 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:56:10.031 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:56:10.031 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:56:10.031 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:56:10.031 WRN rig: β---- End hex dump -----β
2025-02-25 13:56:27.897 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:56:27.897 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:56:27.897 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:56:27.897 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:56:27.897 WRN rig: β---- End hex dump -----β
2025-02-25 13:56:45.772 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:56:45.772 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:56:45.772 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:56:45.772 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:56:45.772 WRN rig: β---- End hex dump -----β
2025-02-25 13:57:03.653 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:57:03.653 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:57:03.654 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:57:03.654 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:57:03.654 WRN rig: β---- End hex dump -----β
2025-02-25 13:57:21.504 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:57:21.504 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:57:21.504 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:57:21.504 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:57:21.504 WRN rig: β---- End hex dump -----β
2025-02-25 13:57:39.376 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:57:39.376 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:57:39.376 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:57:39.376 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:57:39.376 WRN rig: β---- End hex dump -----β
2025-02-25 13:57:57.246 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:57:57.246 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:57:57.246 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:57:57.246 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:57:57.246 WRN rig: β---- End hex dump -----β
2025-02-25 13:58:15.123 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:58:15.124 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:58:15.124 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:58:15.124 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:58:15.124 WRN rig: β---- End hex dump -----β
2025-02-25 13:58:32.985 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:58:32.986 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:58:32.986 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:58:32.986 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:58:32.986 WRN rig: β---- End hex dump -----β
2025-02-25 13:58:50.859 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:58:50.859 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:58:50.859 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:58:50.860 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:58:50.860 WRN rig: β---- End hex dump -----β
2025-02-25 13:59:08.731 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:59:08.731 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:59:08.731 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:59:08.731 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:59:08.731 WRN rig: β---- End hex dump -----β
2025-02-25 13:59:26.607 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:59:26.607 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:59:26.607 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:59:26.607 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:59:26.607 WRN rig: β---- End hex dump -----β
2025-02-25 13:59:44.468 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 13:59:44.468 WRN rig: β---- Begin hex dump -----:β
2025-02-25 13:59:44.468 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 13:59:44.468 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 13:59:44.469 WRN rig: β---- End hex dump -----β
2025-02-25 14:00:02.330 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 14:00:02.330 WRN rig: β---- Begin hex dump -----:β
2025-02-25 14:00:02.330 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 14:00:02.330 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 14:00:02.330 WRN rig: β---- End hex dump -----β
2025-02-25 14:00:20.174 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 14:00:20.174 WRN rig: β---- Begin hex dump -----:β
2025-02-25 14:00:20.174 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 14:00:20.174 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 14:00:20.174 WRN rig: β---- End hex dump -----β
2025-02-25 14:00:38.033 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 14:00:38.033 WRN rig: β---- Begin hex dump -----:β
2025-02-25 14:00:38.034 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 14:00:38.034 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 14:00:38.034 WRN rig: β---- End hex dump -----β
2025-02-25 14:00:55.918 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 14:00:55.918 WRN rig: β---- Begin hex dump -----:β
2025-02-25 14:00:55.919 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 14:00:55.919 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 14:00:55.919 WRN rig: β---- End hex dump -----β
2025-02-25 14:01:13.786 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 14:01:13.786 WRN rig: β---- Begin hex dump -----:β
2025-02-25 14:01:13.786 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 14:01:13.786 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 14:01:13.786 WRN rig: β---- End hex dump -----β
2025-02-25 14:01:31.705 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 14:01:31.705 WRN rig: β---- Begin hex dump -----:β
2025-02-25 14:01:31.705 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 14:01:31.705 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 14:01:31.705 WRN rig: β---- End hex dump -----β
2025-02-25 14:01:49.530 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 14:01:49.531 WRN rig: β---- Begin hex dump -----:β
2025-02-25 14:01:49.531 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 14:01:49.531 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 14:01:49.531 WRN rig: β---- End hex dump -----β
2025-02-25 14:02:07.376 WRN rig: Error (FA) received from rig, last command sent:
2025-02-25 14:02:07.376 WRN rig: β---- Begin hex dump -----:β
2025-02-25 14:02:07.376 WRN rig: "DATA: fe fe 88 e1 1c 01 fd "
2025-02-25 14:02:07.376 WRN rig: "INDEX: 00 01 02 03 04 05 06 "
2025-02-25 14:02:07.377 WRN rig: β---- End hex dump -----β
