Lost connex suddenly
  1. Operating System:
  3. Radio Make and Model:
  4. Method of radio connectivity (USB, WiFi, Ethernet, etc):
  5. Did you check the FAQ and read the manual?
Hi, Ok, I had my xiegu running with wfview then one morning I tried to run it and the op screen came up with no waterfall, just the bare shell. I checked all settings and re-entered username and password nothing. I then loaded the last save data, nothing. I checked radio staus nothing. I tried checked the ip adress still open and not used. I sent a log to termbin.com
Am now charging battery and will be in bed shortly, will pickup tomorrow and do a full uninstall and re-install
73
John
Hi John,
Don’t reinstall, it will not change anything.
Sending logs to termbin does nothing unless you follow the directions and send us the URL that termbin sends you – only then can we read the logs.
It seems to me, from the screenshot, that you are not connected. It also seems like somehow wfview thinks there is an IC-7300 connected.
If you had manually set the CI-V address in wfview, please unset it and go back to automatic. Make sure CI-V Transceive is turned ON on the Xiegu.
Otherwise, make sure you can ping the radio and double-check that the radio’s IP address is what you think it is (it may change sometimes).
Good morning, First look as at the wf server on the x6100 is ok. Everything else looks ok. I then looked at my inet lan to c dongle and saw there was no connection light flashing, just a red power light, so thats probably the cause. Does anyone know of a protected dongle I could use?
Will have to wait for a couple to arrive to test with.
ok, it just decided to work !! What can I say? Happy days and time to play.
73
John
