Would you be willing to add the option to set a Max TX Power % from within WF-View?
I have an amp, and I’m sure a few others do, but I would like to set a limit to the TX power coming out of the 7300 to say 45%. (Normally the icom understand 0 to 100)
So this is what I think should occur:
- If the SW periodically re-sends parameters to the rig, the SW should check if Max Power will be exceeded before sending the parameters
- If the user tries to use the TX Pwr slider to go past limit, the slider jumps back to Max Power setting in the ‘Settings’ page
- If third-party HAM SW tries to set TX Power thru rigctrl, WF-View prevents it from going higher than Max Power.
Actually this could work for any of the icom radios.
