I wish to control an IC-7300 and an IC-9700 from a single windows 11 PC, and also remotely control them (currently on the same network). I have tried to control the IC-9700 using the LAN connection but, although it works on the local PC it does not work from the remote PC. If I set the local Wfview to be a server, I can control from both machines.
All fine so far. However how do I also control the IC-7300? I know that I can setup a second instance of Wfview setup as a server, but how can I control both?
Change settings on the radio itself for individual control
Example
Control port(UDP)
9700 => 50097 7300 => 50073
Serial port (UDP)
9700 => 50098 7300 => 50074
Audio port (UDP)
9700 => 50099 7300 => 50075
Initial Settings
Create a shortcut (e.g. for 7300), activate it, and configure the radio (7300).
I made a mistake in explanation.
The 7300 does not have a server function, so the UDP settings cannot be configured on the radio, but only when using the Wfview server.
But I think you should try and use the 9700 remotely without running your own server. It is worth taking the time to learn how to port forward from the radio and how to get your internal and external ip addresses straightened out. You will face the same challenge with running your own server and accessing it remotely.
Thanks for your advice. I now have both rigs being controlled simultaneously from another PC. This seems to work well. I will still try to sort out the port forwarding as it has other uses as you say
