N1mm and WFview?
Can N1MM control an IC7300 as a remote station over TCP? I have entered the radios IP-address int he N1MM setup windows. But I’m unsure of what port to use?
Backup option virtual com port works fine.
73’s SM0NOR
There is a TCP server within wfview which will allow you to connect N1MM+ to it (rather than using a virtual serial port) this is configured within the External Control tab in wfview settings.
N1MM+ can only connect to directly to an Icom radio over USB/Serial otherwise.
Yes. Sorry for not being clear. I’m trying over the External Control tab. I was just not sure if it was possible. But now the first question is answered with a yes.
Then I was not sure what to fill in regarding the port? Do I chose an arbitrary number as long as it is the same in both ends? For example my.ip.ip:port
Ulf - SM0NOR
Hi Ulf.
In the port box, just enter any number over 1024 (that’s not already in use) then in N1MM+ enter x.x.x.x:port
Has anyone in this forum got this combo to work?
I get this error:
With WFview configured like this:
And N1MM configured like this:
Ulf - SM0NOR
This is working for me. You might try a higher port number.
Can you change the IP address in N1MM to “127.0.0.1:1025” and also make sure any firewall software you have is at least temporarily disabled for this test?
OK. I’ll keep digging!
