Network (wfview client/server) no longer sends audio
Radio Model: ICOM 7300
Connectivity (USB/Ethernet/Wifi/Other): USB to Radio, WIFi/Ethernet between client/server
Operating System: Linux Neon 64-bit x86 on both sides
wfview version (press “About”): 2.03 (but problem surfaced when using “creator-widgets” branch
What I did:
All was working on both the last release and the “creator-widgets” branch. However, I had an update to the Linux systems and suddenly I had no audio coming from the remote. I decided to grab 2.03 with no success. The remote system never shows up in pulse audio (I would think its input/output to the radio would connect via pulse, especially when set to do so). Of course, the system is running pipewire and the pulse interface to it, but still. The log on the server seems ok. On the client side I get:
repeated warnings about QAudioSink(pulseaudio) pa_stream_write invalid argument
It is tricky because, in general, disconnecting the radio and opening settings causes a crash with the message:
Fatal glibc error: pthread_mutex_lock.c:460 (__pthread_mutex_lock_full): assertion failed: robust || (oldval & FUTEX_OWNER_DIED) == 0
So getting it to take different values is dicey.
In addition, the latency numbers when connected seem crazy ranging from normally small to 65535 (0xFFFF).
I have tried QTaudio, Portaudio and on the other side Pulse and direct alsa strings. I have tried various codecs, too.
Expected behavior:
Sound flowing to client computer
Observed behavior:
No sound flowing to client computer
UPDATE:
I changed the IP address to some nonsense which allowed me to get in without crashing and set the audio devices again (they must have changed). Then IP address back. Audio is now fine.
However, now any time the hamlib client (JTDX) tries to change the VFO there is a hamlib error More troubleshooting to follow.
UPDATE #2:
This seems to be the T command issue discussed elsewhere. I kept the server at 2.03 and reverted the client back to 2.01 and all is well…
