1.1 is out for some time and while it seems to be quiet at the front of development, it is not in reality.
We are working on several parallell things and test things out if a feature is feasible.
The stuff that works - we push to the master code branch and as you can see there is
audio-enhance
audioplugins
lv2
master ← this is where we always build the releases from
opus
portaudio
rigs
sequence
shuttle
ui-enhance
and some will never be in , some will. We for instance are also playing with lv2 plugins that can be used to do audio processing. There also is a branch where we want to have an USB device that mimics RC28.
now, when it comes to versioning info…
next will ben 1.2a, 1.2b etc until wel have a stable release which will be 1.20; if bugs need fixing, it will change into 1.21 etc. Next minor releases will follow this way.
A major release will be 2.x.
now 1.2a is almost to be relesed. If you want you can pull the master code and compile yourself. Some already have done that.
What will 1.20 be?
many changes/mods/updates/enhancements to rigctld
rigctld box added in the UI
build process changed: you can add the install prefix (derSuessmann)
added "do not ask again" for switching off rig and exiting wfview
added opus as audio transport
dual meter support
things to come in the future are filter settings, peak filters, nb, nr, dua rx, split mode, dual scope (etc)…
Make the program save the tuning knob setting. I like 10hz but every time I open the program it defaults to 100hz which is too much for cw mouse scrolling.
This has come up a few times and although we could ‘just’ save the tuning step setting, it is a more complex issue as the ‘last’ tuning step may not be appropriate for the current mode, so we are planning a system where tuning steps are saved per-mode.
HAve new 1.2a and works great! Two things: are you going to put color options in top Spectrum and also anything coming soon for more on the 7410? Tnx Ed 73
The IC-7410 should work pretty well out of the box. There won’t be a spectrum display but the radio should work well. Icom ran the USB comms full-duplex to the processor on that radio. Please give it a try and let me know how it goes.
As for the color option on the top spectrum display, currently it can only be customized by manually editing the preferences for wfview. This procedure is outlined in the User Manual under Preference File. One of these days we’ll spend some time and write a UI for this, but for now it’s a manual process.
